Price: $13.90
(as of Sep 28, 2024 20:15:17 UTC – Details)
Lafagiet 3pcs Camping Lighters
4″ Ferro Rod Fire Starter
Outdoor & Candle Lighter
USB-C Arc Lighter
🥇What is multi-purpose lighter?▶For this question, our answer is the one which can be truely used in different occassions. You can’t take a long candle lighter for outdoor adventure. Also one waterproof lighter may be useless in daily use. If you want an EDC gear, this may be your answer either.
🕯️Flexible & Stretchable Hose▶The special innovation of the lighter is built-in 360° flexible, stretchable, high-quality, heat-resisting hose. It combines different needs of outdoor adventure and home daily use. Long hose ignition keep the flame away from you which much better for canlde, stoves. The hose can also be retracted back which much more convenient in storage than other long candle lighter.
🧗♂️BIG Hanging Hole▶Upgrade hanging hole which is much more suitable for carabiner, convenient for hanging on the backpack. Also it comes with one survival lanyard and you can hang on your neck. All in all, this lighter should be your first choice for camping, hiking and fishing etc.
🔌Upgrade TYPE-C charge method▶TYPE C charge is the main trend in our life, more and more products are upgraded with TYPE C charge port. So do we. You won’t bring different cables in your bag, not worried about missing the old usb cables. Also charged by TYPE C can be more stable, faster and safer, protecting the battery and extending the life of lighters.
⛺Wind & Water resistant▶ This is a true IP56 waterproof lighter that performs very well in stormy or windy weather. Any problem please contact Lafagiet after-service team, we will stand by all day long.
