KOORUI Portable Monitor 15.6 Inch 1080P FHD Portable Laptop Monitor IPS Second Screen USB-C HDMI Travel Monitor w/Protective Cover & Dual Speakers 15B1
Price: $69.99 - $59.99
(as of Aug 23, 2024 04:00:30 UTC – Details)
Protable MonitiorProtable Monitior
MonitorMonitor
Take anywhere
Compact in Size – Infinite on Potential
KOORUl portable monitor perfect second monitor for your work and entertainment!can display more image details, smoother and richer dynamic pictures. Its 1.7lb weight and 15.6″size make it easy to carry.
monitor IPS monitor FHD monitor HDMI monitor koorui monitor monitor
15.6 inch monitor monitor 15.6 monitor protable monitor 1 A New Perspective 2 Take anywhere 3 Connect anytime 4 Auxiliary work
How can I increase the brightness of a portable monitor?
When connected to a monitor with 1 USB-C cable, the initial brightness of the monitor is 50%. For extra brightness, make sure to add a USB-C cable and a wall charger to power the monitor.
How do I properly connect a portable monitor?
Type-C:You can directly connect to a laptop other device via a Type-C.
Mini HDMI:Use Type-C and power adapter to provide additional power to the monitor, then connect the device with Mini HDMI.
Is there VESA on the back of the portable monitor?
No
How can I increase the volume?
The built-in dual speakers are 1W, so the volume can only reach 50%.
Every time the connection is lost, the brightness etc. must be readjusted. How can I save the settings?
The monitor doesn’t have a battery, so it can’t save settings, but it’s quick and easy to set up.
ULTRA-PORTABLE MONITOR: KOORUI 15.6 inch portable monitor delivers a vivid image with stunning 1920 x 1080 resolution visuals and awesome color reproduction
FULL HD SCREEN: The 15.6 inch Full HD IPS panel portable screen offer 178°Full viewing angle, weighing just under 2.5 lbs and is about 0.4 inch thick, this 15.6-inch portable monitor can be easily packed and taken with you wherever you go
UPGRADED CONFIGURATION: Built-in dual stereo speaker delivers immersive loud voice; Eye Care technology that keeps your eyes from getting tired during prolonged use
USB-C PORTABLE MONITOR: With dual USB-C Ports and one Mini-HDMI Port, the 15.6 inch computer monnitor can deliver data, audio, video, and power over a single cable
WARM TIPS: When using one USB-C cable connection, the brightness can only reach 50, you need to use one more USB-C cable and match with adaper to connect the power supply to display normally. Headphones that do not support Type-C are used as audio output
SCREEN PROTECTOR: Each monitor comes with a durable screen cover for orientation in both portrait and landscape modes. There are three grooves in the cover base to give at least some choice of viewing angle for your comfort
WIDE COMPATIBILITY: KOORUI usb portable monitor is easily connect laptop, PC, MAC, tablet, smart phones, Switches, etc via Type-c or Mini HDMI port, great ideal for extending your screen or playing games on business trip, travel, or home entertainment
