Price: $11.48
(as of Aug 13, 2024 03:15:21 UTC – Details)
The KEY-BAK #8802 Key Spider Key Carrier is a quality import key holder designed by the makers of the original retractable key reel. Constructed from high quality chrome plated steel, the KEY-BAK #8802 is engineered for years of use. Push button design allows key sets to be removed from device to easily organize up to 5 sets of keys. The included nickel plated steel split rings rotate when inserted in the unit helping them to lay flat in purses or pockets. The KEY-BAK Accessory Series is a line of products designed to hold keys, tools, or anything else you want to keep by your side. This line of high quality key holders have been designed and engineered by the same company that invented the Original KEY-BAK key holder in 1948.
Made in the USA with globally sourced materials and lasts up to 10x longer
High quality import designed by the company that invented the original key security device
Brushed steel finish key spider has 5 removable split-rings
Key spider measures 2.25 inches (5.7 cm) long and fits easily in pockets or purses
Split rings detach and reattach seamlessly keeping key sets separated
