Kello 2200mAh NOAA Emergency Weather Hand Crank Radio, Portable Power Bank with Solar Cell Phone Charging & Battery Operated, AM/FM/SW/Weather Alert with Flashlight, SOS Alarm, Clock (Black)
Price: $42.99
(as of Aug 05, 2024 23:30:13 UTC – Details)
NOAA emergency weather radioNOAA emergency weather radio
noaa emergency weather radionoaa emergency weather radio
NOAA Certified Emergency Radio
Comprehensive broadcast coverage includes AM, FM, SW1 and SW2, plus all 7 pre-programmed national weather channels with real-time alert. Don’t be fooled by other so-called “NOAA weather radios”, chances are they are not certified by National Weather Service or authorized to use its Logo as the Kello TK-669I is.
FM: 88 – 108 MHz AM (MW): 530 -1710 KHz NOAA Weather: 162.400/162.425/162.450/162.475/162.50/162.525/162.55 (continuous band) SW1: 3.20- 8.00 MHz SW2: 9.00- 22.00 MHz
Be Prepared for the Worst
Life is full of uncertainties, emergencies often occur unexpectedly and natural disasters sometimes strike without any warning signs. The least we could do is to be prepared by having important emergency supplies readily available, making a plan for yourself and your loved ones, and being informed.As reported, we used to experience several times natural disasters per year like hurricanes”Harvey”, Wildfire, and so on. The emergency weather Radio will keep your family safe through it all. This Weather Radio can timely report emergency weather alerts in your areas to be well prepared;
emergency radioemergency radio
Solar Powered
In strong direct sunlight, the internal battery is charged with the solar panel on top.
Hand Crank
charge this NOAA weather alert radio by hand crank.
Polymer Lithium Battery
Long Battery Life
2200 mAh rechargeable Li-Ion battery gives up to 40 hours of continuous use.
USB 2.0 Charging
USB-C charging is the most convenient and fast charging method to obtain electric quantity for daily use and fully charge the hand crank radio as fast as 6 hours.
AM FM NOAA / weather alert function100LM super bright flashlightLoud SOS AlarmIPX4 Waterproof——With the IPX4 waterproof, small raindrops splashing on this NOAA emergency weather radio will not make damage (But please do not soak in water).The built-in 2200mAh rechargeable battery not only powers the weather radio noaa alert, but can also be used as a power bank to charge your phone or other devices in case of emergency, so you can always stay connected.
Warm Tips
Please don’t crank the radio when Lithium battery is not installed or insulation tab is not removed!Please do not leave on charge continuously when the battery is fully charged. Take battery out if you to do so.If the unit is not to be used for an extended period of time, remove the batteries.Periodically charge the Lithium Ion battery to extend battery life.Radio reception is dramatically reduced when charging from USB. Disconnect USB power when listening to the radio.
TK-669I is emergency radio which officially certified by NOAA,contains 2200mAh power bank,capable of providing emergency power for any small tablet computer or mobile phone, as an emergency mobile battery charger with built-in standard DC 5V USB output port for charging mobile devices, such as smart phones, GPS devices, digital cameras, etc.
This device offers extensive and precise reception of AM FM, 2-band shortwave, and 7 pre-set NOAA weather channels, allowing for access to various forms of entertainment, sports, global news, and around-the-clock weather updates (in the United States only) through the PEAS (Public Emergency Alert System).
The radio can be powered by three sources: a battery with a capacity of 2200mAh, a solar panel, and a crank lever. The solar panel and crank lever are both capable of recharging the battery and keeping the radio functioning even when other power sources are unavailable.
Put the TK-669I radio on Alert mode, which will automatically turn on once it receives a signal indicating a weather alert from NOAA stations.
TK-669I is made of high quality impact resistant and waterproof ABS material, suitable for both indoor/office use and outdoor entertainment
