Price: $19.99 - $12.99
(as of Aug 10, 2024 16:45:21 UTC – Details)
Control your lights, ceiling fans, and other fixtures from anywhere with the HS200. The smart switch replaces any standard light switch, and connects to your home Wi-Fi in no time through the free Kasa app. Kasa also lets you manage connected fixtures with your smartphone or tablet, including setting schedules, timers and countdowns. For added convenience, you can use your voice to control the HS200 when paired with works with Amazon Alexa, Google assistant and Microsoft cortana.Input Voltage: 100 – 120 VAC, 50/60 Hz, 15 A.
Product Dimensions : 1.5 x 3.3 x 5 inches; 5.28 ounces
Item model number : HS200
Date First Available : June 1, 2016
Manufacturer : TP-LINK USA
ASIN : B01EZV35QU
Country of Origin : Vietnam
Easy guided install: Neutral wire is required, standard wall plate size. No need to understand complex switch wiring or master vs auxiliary switch configurations; The Kasa app guides you through easy step by step installation. Need 2.4GHz Wi-Fi connection
Control from anywhere: Monitor your light status. Turn electronics on and off from anywhere with your smartphone using the Kasa app, whether you are at home, in the office or on vacation
Voice control: Enjoy the hands-free convenience of controlling the lights in your home with your voice via Amazon Alexa or Google Assistant; perfect for times when your hands are full or entering a dark room
Scheduling: Use timer or countdown schedules to set your smart switch to automatically turn on and off while you’re home or away. Enable ‘away mode’ to randomly switch on and off to trick potential intruders
Trusted and reliable: Designed and developed in silicon valley, Kasa is trusted by over 4 million users. UL certified for safety use. Dimensions without panel 4.13*1.71*1.74 in. (105*43.5*44.21 mm). System Requirements : Android 5.0 or higher, iOS 10 or higher
