JOINLGO 8 Channel Mobile DVR Backup Camera System Remote Monitor on PC Phone GPS WIFI 4G 1080N AHD Vehicle Car DVR MDVR Video Recorder with 8 1080P sensor Car Cameras for Truck/RV/Bus
Price: $449.89
(as of Aug 27, 2024 15:30:13 UTC – Details)
BRAND-BANNERBRAND-BANNER
N38-4GW-BANNERN38-4GW-BANNER
JOINLGO 1080P 8-CH Moible DVR Camera System
All-In-One Surveillance System Included:
1 x 8CH 1080P SSD 4G GPS WIFI Mobile DVR.8 x 1080P AHD NTSC mode car camera.2 x 65ft cable, 4 x 33FT 4 pin cable. 2 x 16.5ft cable,1 x 7 inches IPS VGA car monitor.1 x Accessory for MDVR.1 x 10ft GPS antenna, 1 x 10ft 4G antenna, 1 x 10ft wifi antenna1 x User Manual.Note 1: memory card and HDD NOT Included.Note 2: Support DIY to select the cameras and cable length in the kit.
use-SONY-sensoruse-SONY-sensor
Excellent Image Quality
With brand IMX323 sensor and IMX307 sensor, and 6-layer HD lens. The camera gets the best quality 1080P video.Good quality chip that have better WDR function. it can get clear image at any illumination.
EASY INSTALLATIONEASY INSTALLATION
Easy Mount
Just drill a hole in your vehicle and adjust the angle of the lens to a suitable direction.Camera used high-quality metal materials, can effectively prevent rust, Can be installed outside vehicle. Default 120° wide view angle.
waterproofwaterproof
IP69 WATERPROOF CAMERA
The AHD cameras are rated as dust tight and waterproof and cover with durable housing. Not afraid to brave the snow, rain, or heat.Cameras’ operating temperature can be ranged from -40°F to 122°F (-40°C to 50°C)
night visionnight vision
NIGHT VISION
Featuring 2.8mm LEDs with IR-CUT function, 120° viewing angle, 50ft Night Vision range.The camera’s infrared mode is automatically activated in low lighting conditions. It can clearly monitor everything even at night.
EXCELLENT CAMERA
Easy Installation
IP68 WATERPROOF CAMERA
NIGHT VISION
DELAY POWERDELAY POWER
G-sensorG-sensor
live gpslive gps
remote accessremote access
DELAY POWER OFF
Records footage while vehicle is off– up to 24 hours (draws power from vehicle’s battery).8 second power off delay– protects data for 8 seconds if DVR loses power completely (draws power from built-in capacitors).
G-SENSOR
Recognizes sudden movements i.e. hard acceleration, sudden stops, speeding and impacts. Can set alerts to to keep these recordings as eventsCMSV6 can also receive the G-sensor alarm real-time.
LIVE GPS TRACKING
Built-in GPS module. Real-time record GPS tracking and speed.Record (and view remotely) vehicle speed and location together with footage as well as the route the vehicle has driven.We provide a free playback software (can only work on Windows PC). It can playback the tracking and speed on the software.
LIVE VIDEO REMOTE VIEWING
DVR connects to 4G network or WiFi hotspot in vehicle. View and download footage remotely while vehicle is on the road. Perfect for fleet management!We are providing free mobile APP “CMSV7” (iOS & Android) and PC Client. It can also remote access via webpage.
Motion DetectionMotion Detection
N24-N38-STORAGEN24-N38-STORAGE
IO-4channelIO-4channel
8-CH display8-CH display
Motion Detection
The DVR software supports motion detection. It does not need extra motion detectio sensor. The motion detection alarm is TURNED OFF IN DEFAULT. If you need this function, please enter menu to turn on this alarm. MDVR will automatically save videos and output alarm when detects an alarm. also will upload the alarm to CMSV7.
If you connect a device with the alarm output cable, it will active this device.
8-CH Loop Record
8-channel 1080P loop recording.I will use 0.6G storage for one camera to record one hour. It also setup recording resolution at 960H/D1/CIF to save space.With 2 memory slot and one 2.5″ SSD slot. each memory card slot supports maximum 512 GB . the HDD slot supports maximum 4TB HDD or SSD.
I/O Alarm
The DVR supports 4-CH I/O inputs and 1 alarm output. It can set those inputs to record vehicle backing, turning left/right, door openning and more. Also, they can be simply used as a panic button, or work with other external sensors to trigger recording or send out alarm signal to external device.
Multi Mode Display
Supports to setup 1CH/2CH/3CH/4CH/5CH/6CH/8CH display. Support to horizontal flip or vertical flip each channel image.
8-CHKIT-INSTALL8-CHKIT-INSTALL
4.0 out of 5 stars
51
60
4.1 out of 5 stars
47
4.2 out of 5 stars
26
$29.98$29.98 $449.89$449.89 $399.98$399.98
Live View
GPS
4G
Wifi
Storage
1 x 2TB HDD & 2 x 512GB SD 2 x 512GB SD 1 x 2TB SSD & 2 x 512GB SD 1 x 2TB HDD & 2 x 512GB SD
SD/HDD
not inclued not inclued 1TB SSD not included
Screen Size
7″ 7″ 10.1″ 10.1″
【EASY WIRING】: PLUG AND PLAY. Wiring via 4 pin connector. Car Monitor gets power from mdvr via DC connector. We also provide a free PC software, used to palyback recording videos and GPS tracking on PC. 【Intercom】There is a intercom talk port on the mdvr, if you connect a intercom handle, then you can intercom between car and CMSV6 center.
【WIFI 4G and GPS】:Built-in WIFI , 4G and GPS module. Easy to search and connect with wifi hotpot . support 4G SIM card. Support remtoe live view on PC, webpage and IOS/Andriod smartphone. CMSV6 APP and BEIDOU platform. free server. 【HD MI Output】MDVR with HD MI output, it can connect with TV or your monitor that has HD MI input. 【G-sensor]】Built-in G-sensor module, it will record alarm video and send alarm message to CMSV6 when an crash happens
【LOOP RECORD】: 8 Channel 1080N (1080N/720P /960H/D1/CIF for selection) HD real time recording, loop recording, Supports one Hard driver and 2 piece memory card. (Max.512GB x 2, 2TB HDD x1, memory cards are not included). Support upgrade software via USB slot. the USB slot also supports to backup videos. Support playback videos on screen. Support video searching function so that we can easily get files of a certain period.
【EXCELLENT CAMERA】: IP68 Rate waterproof, can work in outside directly. IR LED for night vision. Full metal case material, brand sensor + WDR board, excellent image quality in both day and night. 2.8mm lens, 120 degree view angle.We do waterproof test on every cameras. The 7″ car screen is VGA connector. screen resolution: 1024*800. 【Motion Detection】Supports to set motion detection alarm.
【DELAY RECORDING】: it can set delayed recording and delayed power off via OSD menu. time can be setup to 24 hours. 【4-CH ALARM INPUT】: It supports 4 channel sensor inputs, it will show full screen of one channel automatically when recieve the trigger signal, like reverse, turn light etc. 【Worry-Free Warranty】Easy-to-reach lifetime email support. And you can always rely on our 24/7 customer service. 2 YEARS WARRANY, Free replacement for any defective item. Life-time repairment service.
