Price: $399.98
(as of Aug 24, 2024 18:15:17 UTC – Details)
【EASY WIRING】: PLUG AND PLAY. Wiring via 4 pin connector. Car Monitor gets power from mdvr via DC connector. We also provide a free PC software, used to palyback recording videos on PC. 【Intercom】There is a intercom talk port on the mdvr, if you connect a intercom handle, then you can intercom between car and CMSV7 center.
【WIFI 4G and GPS】:Built-in WIFI , 4G and GPS module. Easy to search and connect with wifi hotpot . support 4G SIM card. Support remtoe live view on PC, webpage and IOS/Aandroid smartphone. CMSV6 APP and BEIDOU platform. free server. 【HD-MI Output】MDVR with HD-MI output, it can connect with TV or your monitor that has HD-MI input. 【G-sensor]】Built-in G-sensor module, it will record alarm video and send alarm message to CMSV6 when an crash happens
【LOOP RECORD】: 8 Channel 1080N (1080N/720P /960H/D1/CIF for selection) HD real time recording, loop recording, Supports one Hard driver and 2 piece memory card. (Max.512GB x 1, 4TB SSD/HDD x1, 1TB SSD is included).. Support upgrade software via USB slot. the USB slot also supports to backup videos. Support playback videos on screen. Support video searching function so that we can easily get files of a certain period.
【EXCELLENT CAMERA】: IP68 Rate waterproof, can work in outside directly. Without IR LED, color image in night vision . 2.8mm lens, 120° Ultra-large Viewing View. Full metal case material, Real 2.0MP HD resoluiton.【10.1 inches HD-MI SCREEN】 The 10″ car screen is VGA&HD-MI connector. screen resolution: 1280*800. 【Motion Detection】Supports to set motion detection alarm.
【DELAY RECORDING】: it can set delayed recording and delayed power off via OSD menu. time can be setup to 24 hours. 【4-CH ALARM INPUT】: It supports 4 channel sensor inputs, it will show full screen of one channel automatically when recieve the trigger signal, like reverse, turn light etc. 【Worry-Free Warranty】Easy-to-reach lifetime email support. And you can always rely on our 24/7 customer service. 2 YEARS WARRANY, Free replacement for any defective item. Life-time repairment service.
