Price: $259.89
(as of Aug 03, 2024 09:30:22 UTC – Details)
JOINLGO 1080P 4-CH Moible DVR Camera System
All-In-One Surveillance System Included:
1 x 4CH 1080P Mobile DVR.4 x 1080P AHD NTSC mode car camera. 2 x 33FT 4 pin cable, 1 x 16.5ft 4 pin cable, 1 x 50ft 4 pin cable.1 x 7 inches IPS VGA car monitor.1 x accessory for MDVR.1 x User ManualNote 1: memory card NOT Included.Note 2: Support to DIY select different cameras and cable length in this kit.
Hassle Free Connection
Connect the car cameas with mdvr via 33 ft 4-pin connector cables. Power the MDVR via the car battery. Connect 7″ monitor with the MDVR via VGA connector. Power the monitor via the 12VDC output cable of MDVR.The stable and stream video will show up on the monitor. (If you want to remote on a smart device, you need to buy the MDVR with 4G or wifi module)Comes with 4 pieces 33ft cable. You can also buy 16ft/49ft/ 65ft cables as needed.
4-CH 1080P Loop Recording
4-channel 1080P AUDIO AND VIDEO loop recording. If set record resolution at 1080P. I will use 1.5G storage for one camera to record one hour. It also setup recording resolution at 720P/960H/D1/CIF to save space.With 2 memory card slot. each memory card slot supports maximum 256 GB card. Please lock the memory card door, or MDVR won’t work.Convenient to palyback videos and backup videos on mdvr.
7″ HD IPS Monitor
IPS screen. VGA connector. It can get clear image at any perspective.Resolution at 1024*600. It shows HD image at this screen. adjustable colorness and contrast.It can dash mount or flush mount. Easy to install.
Easy Mount
Just drill a hole in your vehicle and adjust the angle of the lens to a suitable direction.Camera used high-quality metal materials, can effectively prevent rust, Can be installed outside vehicle. 2.8mm lens. 120° wide view angle.
Easy Setup
1080P Dual SD MDVR
7″ IPS VGA Screen
Easy Mount
NIGHT VISION
Featuring 2.8mm LEDs with IR-CUT function, 120° viewing angle, 50ft Night Vision range. The camera’s infrared mode is automatically activated in low lighting conditions. It can clearly monitor everything even at night.
IP68 WATERPROOF CAMERA
The AHD cameras are rated as dust tight and waterproof and cover with durable housing. Not afraid to brave the snow, rain, or heat.Car cameras’ operating temperature can be ranged from -40°F to 158°F (-40°C to 65°C)
Multi-Ways Playback Videos
1. Enter menu to search and playback videos on MDVR directly. Also supports to fast forward and rewind.
2. Backup avi video from USB slot of mdvr. play via common player directly.
3. Backup H.264 files or just take out the SD cards. Playback the H.264 files on our player software. It supports to playback 4 channels video at same time.
G-SENSOR & Delayed Record
Built-in G-sensor module.Recognizes sudden movements i.e. hard acceleration, sudden stops, speeding and impacts. MDVR will save video automatically when an accident happens.
It supports to set keep recording footage while vehicle is off– up to 24 hours (draws power from vehicle’s battery).
I/O ALARM
The DVR supports 4-CH I/O inputs and 1 alarm output. It can set those inputs to record vehicle backing, turning left/right, door openning and more. Also, they can be simply used as a panic button, or work with other external sensors to trigger recording or send out alarm signal to external device.
MOTION DETECTION
The DVR software supports motion detection. It does not need extra motion detectio sensor. The motion detection alarm is TURNED OFF IN DEFAULT. If you need this function, please enter menu to turn on this alarm. MDVR will automatically save videos and output alarm when detects an alarm. If you connect a device with the alarm output cable, it will active this device.
4.7 out of 5 stars
5
4.0 out of 5 stars
9
4.2 out of 5 stars
52
3.7 out of 5 stars
17
4.1 out of 5 stars
47
3.9 out of 5 stars
50
— $375.00$375.00 $289.99$289.99 $399.98$399.98 $29.98$29.98
GPS
Storage
1 x 2TB HDD/SSD and 2 piece 512GB SD 1 x 2TB HDD/SSD and 2 piece 512GB SD 1 x 2TB HDD/SSD and 2 piece 512GB SD 2 piece 512GB SD 2 piece 512GB SD
HDMI
WIFI
Remote Live View
4G LTE
Screen Size
7″ 10.1″ 7″ 7″ 7″
【Easy Wiring】: PLUG AND PLAY. Wiring via 4 pin connector, connector with waterproof rubber ring. Wired car camera system can get more stable video than wireless system when driving fast【Hd-mi Output】It supports to connect with TV or monitor that with hd input. Dvr supports works with 2 monitors synchronously. 【usb】It supports to backup avi videos through usb port. It can also connect a mouse via the usb slot.
【Loop Record】: 4-CH 1080P (720P /960H/D1/CIF for selection) HD real time recording. Records camera feeds continuously, looping over oldest recordings when storage is full. Records onto two Memory cards – each with a 256GB capacity. This gives the DVR a total storage capacity of 512GB.(card not included in this kit). 【Playback】Support playback videos on mdvr. We also provide a free PC software, which used to palyback recording videos on PC.
【Camera】: IP68 Rate waterproof, can work in outside directly. Full metal case material, rubost and durable.18 pieces IR LED for night vision. Real 2.0MP resoluiton. Excellent image quality in both day and night vision. One camera without IR is installed in front of windshield, which will avoid the reflection issue at night【7″ Screen】IPS VGA Monitor. Screen resolution: 1024*600.【Mirror Image】It can mirror image on MDVR
【Delay Record】: Records footage while vehicle is off – up to 24 hours (draws power from vehicle’s battery).【G-sensor]】Recognizes sudden movements i.e. hard acceleration, sudden stops, speeding and impacts. Can set alerts to to keep these recordings as events.【4-ch Alarm Input】: It supports 4-ch alarm inputs, the screen will show full screen of one channel automatically when recieve the trigger signal. Manually create alarms so that associated footage is overwrite protected.
【Motion Detection】 the motion detection alarm is off in default, please turn on it if you need. The settings is in the OSD menu of MDVR. 【Warranty and Service】 2 Years Warranty, Free new item to replace during the warranty. life-time technical service.
