Jensen JTV19DC HD Ready 19 Inch 12V DC RV LED TV with Integrated HDTV (ATSC) Tuner, HD Ready (1080p, 720p, 480p), 1366 x 768 Full HD, Dual Function Wireless Remote Control, Black
Price: $216.75
(as of Aug 21, 2024 17:30:15 UTC – Details)
JENSEN JTV19DC HD Ready 19″ Inch LED TV, 12V DC, specially built for Boats, Yacht, RV Recreational Vehicle, Trailer, Camper, Motor Home etc.
JENSEN…the ONLY brand of TVs designed, engineered, tested & built exclusively for over-the-road applications.
The JTV19DC set features a more modern aesthetic and robust chassis than traditional RV TVs. A design unique to the RV industry, this model includes a market-first industrial grade metal cabinet that’s reinforced for vibration. With true native 12V operation, a slim profile, front firing speakers and convenient front controls, the JTV19DC addresses a multitude of application challenges faced by the motorhome manufacturer.
Inputs/Outputs
  • Composite video input x 1 (NTSC/PAL)
  • Component video input x 1
  • Stereo audio input x 1
  • VGA with 3.5mm audio input x1
  • RF x 1
  • USB media play
  • HDMI input x 1 (Supports ARC)
  • Selectable (variable/fixed) line level audio output (RCA) x1
  • Digital SPDIF audio output (RCA)
  • Headphone output
Specifications
  • Power System: DC 12V
  • Power Consumption: 11mA stand by, 1.960A max
  • Operating Temperature Range: -4°F to 149°F -20°C to 65°C
  • Storage Temperature Range: -22°F to 158°F -30°C to 70°C
  • Maximum Relative Humidity: 85%
  • Overall Dimensions: 17.9″ W x 11.6″ H x 1.8″ D
  • Product Weight: 5.5 lbs
  • Regulatory Certification(s): FCC
Performance
  • Video / Display System: NTSC/ATSC/PAL
  • Video Input Signal (Composite): 1Vp-p @ 75 ohms
  • Audio Output: 3W x 2
LCD
  • Diagonal Size: 18.5″
  • Resolution: 1366 x 768
  • Brightness: 200 nit
  • Contrast Ratio: 3000 : 1
  • View Angles: Top 80°, Bottom 80°, Left 85°, Right 85°
  • Display Format: 16:9
  • Response Time: 5.0 ms
This is a 12V DC Product Only, A Power Inverter is required to connect to 120V AC (Not included), Integrated HDTV (ATSC) tuner, HDTV-ready (1080p, 720p, 480p)
High performance wide 16:9 LCD panel, 16.7 million colors, JCOM function with JENSEN HDMI-equipped DVD player (Not Included)
Convenient front controls, Conformal coated circuit boards, Rugged metal cabinet, Reinforced cabinet structure and mounting points
ARC (Audio Return Channel) via HDMI, VESA 100mm x 100mm mounting pattern
Dual function wireless remote control (TV/DVD) included (a external DVD Player has to be purchased separately). Optional table top stand (STDJE1914) sold separately
