Jasion EB5 Electric Bike for Adults with Peak 500W Brushless Motor, 40Miles 20MPH Commuting Electric Mountain Bike with 360Wh Removable Battery, 7-Speed, 26″ Tires and Front Fork Suspension
Price: $399.99
(as of Sep 29, 2024 17:15:19 UTC – Details)
A sturdy high-step commuter-style electric bike offering up to 20 mph on demand, uses the same 350-watt motor and 36-volt battery, as a commuter bike travel effortlessly across town, and commute to work faster without fuss, fatigue, or sweat – all while wearing your everyday attire.
It’s easy to ride with a lightweight design. It has tough 26’’ road tires, pedal assist with a push-button throttle and 7-Speed gear.
In short, Jasion EB5 e-bike was expertly designed for city living.
350 W Motor & Upgraded Display: The EB5 electric bike equipped with a 500 W peak motor, boosted a top speed of 20 MPH. The display panel has adjustable backlight brightness from 1-5 levels. In addition, the upgraded LCD Display provides riding data support, such as ODO/MAX/AVG SPEED, PAS mode can be customized up to 3 modes
Removable Large Battery: The EB5 e-bike is equipped with a 360 Wh battery, which covers a range of up to 25-40 miles per charge for 5-6 hours so that it can meet travel or daily commute needs. Removable battery makes charging more convenient whether you are at home or in the office
4 Working Modes: PAS mode will assist you with a moderate amount of power as you pedal the bike, kick in 1-3 levels of pedal assist to suit your needs. In pure electric mode, you can twist the throttle in any increments of power you desire. Pedal mode allows the rider to pedal as an ordinary bike. Booster mode will help you push your EB5 at 4.5-7.5 km/h when uphill, which will save you a lot of efforts
Riding Comfortably and Handily: The 26″ puncture resistant tires are for greater durability. A high-strength front fork suspension, 7-speed gears, dual lights, LCD display, front and rear mechanical disc brakes can bring your riding more comforts, make your e-bike adapted to complex terrains and keep you safe
Minimalist Appearance & Lightweight Frame: A highly efficient, city style affordable electric bicycle offering minimalist and sleek appearance and only weighs 49.6 lbs. The triangular high-carbon steel frame provides more stability
