Jansite Wireless Backup Camera HD 1080P 7” DVR Monitor with IP69 Waterproof RV Rear View Camera Stable Digital Signals 150°Wide Angle Touch Key Back Up Camera for trailers,Vans, Trucks, Large Vehicle
Price: $49.95
(as of Sep 22, 2024 11:15:16 UTC – Details)
JansiteJansite
Backup Camera Kit 1Backup Camera Kit 1
Backup Camera Kit 3Backup Camera Kit 3
Backup Camera Kit 4Backup Camera Kit 4
Backup Camera Kit 5Backup Camera Kit 5
Backup Camera Kit 6Backup Camera Kit 6
Backup Camera Kit 7Backup Camera Kit 7
7 Inch HD 1080P Touch Screen
Newly upgraded touch buttons,more convenient and sensitive than traditional buttons.Wireless backup camera with HD 1080P monitor, Digital High Definition Image Processor HD Image will make you more confident and safer when reversing.
Split Screen with 4 Channel
The rv backup camera monitor has Split screen ability with 4 cameras,You can add extra digital wireless rv rear view camera to the current monitor.
Loop Recording
The wireless back up camera systems for truck built in record function and loop recording, continuous record when memory card is full and auto erase old files.
Backup Camera Kit 8Backup Camera Kit 8
Backup Camera Kit 9Backup Camera Kit 9
Backup Camera Kit 10Backup Camera Kit 10
Parking assist lines
You can turn on/off the Rear assist marker lines according you need. The wireless rv backup camera can help you reverse safely. With coverage right down to the bumper, it’s easy to see blind spots and hidden obstacles when backing up.
Image Flip
Jansite wireless camera system for rv with the image flip function, the image switches between four modes: up, down, left and right, you can adjust the viewing angle as needed.
Since the back image can be switched between normal image and mirror image, it can be used not only as a rear backup camera but also as a front camera.
Wide viewing angles
The backup camera kit with a 150° viewing angle for doorway and rear cameras, Jansite rv backup camera gives you visibility all around your RV to reduce blind spots and makes reversing easier and safer.
Backup Camera Kit 11Backup Camera Kit 11
Backup Camera Kit 12Backup Camera Kit 12
Backup Camera Kit 13Backup Camera Kit 13
IP69 Waterproof Camera
All-metal production,waterproof and durable, high temperature and low temperature resistance, extreme weather can continue to work.
Two types of installation
►The rv camera system wireless monitor is supplied with 2 different mounts to mount .
►The wireless rv backup camera bracket canbe adjusted at any angle for easy installation.
Easy to install
Make all things much easier.
1. Power the monitor by the included cigarette lighter or Fuse box, ACC, Radio, Ignition switch. 2. Connect the rear camera to continuous power source like Tail light/Running light/license plate light for monitoring, or connect to backup light for reversing only.
【Wireless Design for Easy Installation】With wireless technology, the monitor and camera auto connected wirelessly, you don’t need pull long cables from camera to monitor,make all things much easier. Upgraded wireless backup camera is powered by a cigarette lighter, Simply press the power button for a perfect reverse or image recording
【Stable Image】Jansite newest wireless rv backup camera system with digital wireless transmission and three antennas, power, transmission distance, stability, durability are improved by at least 60%. The rv rear view camera can send 1080P videos to the display via the stronger signal. The signal can reach 360ft(110m) in open area and working on vehicle range under 320ft(98m). Thus wireless back up camera systems for truck is suitable for all most of long vehicles
【1080P Full HD Recording System】The wireless backup camera with HD 1080P monitor, high definition image processor will make your backing more confident and safe. The back camera for car reverse supports record 4 wireless truck cameras at the same time and loop recording. Saving the video automatically just in case,and you can play back the video on the monitor. Upgraded rv back up camera monitor can switch Dual/Quad Split screen
【Upgrade Waterproof Rear View Camera】Fully sealed unique structure rear camera kit, our wireless rear backup camera kit meets IP69 international standard of waterproof. Use glue filling process, which avoids the penetration of water vapor even in heavy rain. Excellent waterproof and impact resistant performance, to effectively extend the service life
【7-inch Large Screen IPS Material Monitor&Thoughtful Design】The rv backup camera wireless with monitor is equipped with an IPS liquid crystal panel, which realizes vivid color expression and contrast with little color change from any angle. Equipped with sun visor so you can see clearly even in direct sunlight. The backup camera for truck screen angle can also be adjusted according to personal habits
【Wide Angle for Safe parking & Professional After-sales Service】Wireless backup camera for rv with wide detecting range, this rv camera system wireless backup camera captures more details to reduce video shooting blind area (such as child, some pets and etc). you can avoid scratches, bumps and park your vehicle safely and effortlessly. ※ 24-hour after-sales service and professional technical team. If you encounter any problems, please feel free to contact us
