Price: $337.00
(as of Aug 22, 2024 10:15:27 UTC – Details)
1 CLEAN SOLAR RECHARGE 2 FAST AC RECHARGE
1 EASY TO USE 2 SAFE & RELIABLE
SPECIFICATIONS
Capacity 1534Wh (60.9Ah/25.2V) AC Output 3 x 110V~ 60Hz, 16.4A, 1800W (3600W Peak) USB-A Output 5V-2.4A Quick Charge 3.0 Output 18W, 5-6.5V-3A, 6.5-9V-2A, 9-12V-1.5A USB-C Output PD 60W, 5V-3A, 9V-3A, 12V-3A, 15V-3A, 20V-3A Car Output 12V-10A DC Input 2 x 48V-6.25A (Double to 500w Max) Battery Lithium-ion Battery Weight: 35.3 lbs Dimension 14 x 10.4 x 12.7 inches LED Flashlight SOS LED Operating Temperature 14-104°F (-10-40℃) Recharging Temperature 32-104°F (0~40°C)
FAQ
Q1: What devices can Explorer 1500 power?
A: The Explorer 1500 can charge/power devices that operate at less than 1800 watts and the total wattage of all connected devices should also be under 1800 watts as well. If the power requirement exceeds this limit, the Explorer 1500 will automatically shut off. Please check your device’s specifications before making a purchase.
Q2: How can I know the working time for my device?
A: You can calculate the working time using the formula: Working time = 1534Wh*0.85/operating power of your device. For example, if the power consumption of your device is 60W, the estimated working time would be approximately 21.7 hours. Please note that actual power consumption may vary based on different usage scenarios.
Q3: Can the Explorer 1500 can be used as UPS?
A: No, the E1500 can’t be used as UPS as it is required to press the power button to turn on the AC/USB/DC output.
Q4 :Why it takes a longer time to charge the power station from 80% to 100%?
When charging the power station at a low power, such as during the constant current stage, the charging power is at its maximum. As the power increases, the internal battery pack voltage of the energy storage gradually rises to the charging limit voltage, and then it enters the constant current stage where the charging power gradually decreases until it reaches full capacity. During the later stage of charging, the power gradually decreases. Please note that charging to 100% may take a considerable amount of time.
COMPARISON Capacity 518Wh 1002Wh 1512Wh 2160Wh 3024Wh 4085Wh 2042Wh Output Wattage 500W 1000W 1800W 2200W 3000W 3000W 3000W Parallel Connection
Maximum Expandable Capacity 518Wh 1002Wh 1512Wh 2160Wh 3024Wh 12kWh 12kWh Maximum Output Wattage 500W 1000W 1800W 2200W 3000W 3000W 3000W AC Full Recharge Time 7Hrs 1.8Hrs 2Hrs 2Hrs 2.4Hrs 2.3Hrs 2Hrs Solar Panel Full Recharge Time 9Hrs(1*100W) 1.8Hrs(4*200W) 2Hrs(6*200W) 2.5Hrs(6*200W) 3.5Hrs(6*200W) 4Hrs(6*200W) 2Hrs(6*200W) Net Weight 13.3 lbs 25.4 lbs 37.4 lbs 43.0 lbs 63.9 lbs 105.2 lbs 61.5 lbs
Clean and Unlimited Solar Energy: 100% clean and unlimited solar energy with smart MPPT controller for your camping or family emergency storage. The power station can be charged for 0% to 80% with 4 Jackery SolarSaga 100W solar panels within 4 hrs or only 4 hrs via AC wall outlet charging.
Easy to Use: The ergonomic shape of the handle grants an ease grip. And use in one touch with simple and speedy setup within 60s to enjoy outstanding charging efficiency and ensure quiet and peaceful charging.
Safe & Reliable for Outdoor Camping: Features industry-leading cylindrical batteries (popular with manufacturers of Electric Vehicles) that meet UL safety standards. Certified with Impact-Resistance Class 9, passing the UL drop test (withstanding 3 drops from 0.9m height on any surface). The pure sine wave inverter delivers constant voltage that protects equipment from damage.
Power Pretty Much Anything: Power with 1534Wh capacity (1800W AC output power) and 7 outlets (3*AC outlet, 1*USB-A quick charge 3.0, 1*USB-A, 1*USB-C PD 60W, 1*Car outlet). Ideal for outdoor off-grid activities and home backup power to power the most of your appliances – refrigerator, TV, mini cooler, electric grill, fan, and more for your outdoor and home needs.
Quiet & Strong: At a such large capacity, this Explorer will leave you with VERY LITTLE to NO noise, giving you the peace and power all at once. Extra bonus for the built – unlike most other portable generators, this supports pass-through charging while its battery life is protected.
What You Get: 1*Jackery Explorer 1500 Portable Power Station, 1*AC&AC Cable, 1*Car Charger Cable, 1*User Manual.
