Price: $2,499.00
(as of Aug 24, 2024 02:45:20 UTC – Details)
1 Plug&Play 2 Ultra-Long Standby 3 Advanced Smart Screen 4 Safe in Every Way
SPECIFICATIONS
Output power (front) 1000W 3 x AC Output 120V~ 60Hz, 8.33A Max, 1000W rated output, 2000W peak surge 2 x USB-A Output Quick Charge 3.0, 18W Max 5-6V⎓3A,6-9V⎓2A,9-12V⎓1.5A 2 x USB-C Output 100W Max 5V⎓3A, 9V⎓3A, 12V⎓3A, 15V⎓3A, 20V⎓5A AC Input 120V~ 60Hz, 15A Max DC Input: 12V-17.5V(Working Voltage)⎓8A Max, Double to 16A Max 17.5V-60V (Working Voltage)⎓11A, Double to 22A/800W Max Charge Temperature: 0~40 °C (32~104 ℉) Dimensions 13.39×10.32×10.06 in weight 47.9 lbs
Comparison Capacity 518Wh 1002Wh 1512Wh 2160Wh 3024Wh 4085Wh 2042Wh Output Wattage 500W 1000W 1800W 2200W 3000W 3000W 3000W Parallel Connection
Maximum Expandable Capacity 518Wh 1002Wh 1512Wh 2160Wh 3024Wh 12kWh 12kWh Maximum Output Wattage 500W 1000W 1800W 2200W 3000W 3000W 3000W AC Full Recharge Time 7Hrs 1.8Hrs 2Hrs 2Hrs 2.4Hrs 2.3Hrs 2Hrs Solar Panel Full Recharge Time 9Hrs(1*100W) 1.8Hrs(4*200W) 2Hrs(6*200W) 2.5Hrs(6*200W) 3.5Hrs(6*200W) 4Hrs(6*200W) 2Hrs(6*200W) Net Weight 13.3 lbs 25.4 lbs 37.4 lbs 43.0 lbs 63.9 lbs 105.2 lbs 61.5 lbs
Dual-Sided Enhanced Power Generation Efficiency by 25%: 1002Wh capacity with an output power 1000W. Takes 1.8 hours for a full wall & solar (4*SolarSaga 200) charge and supports 1000 charge cycles. Pairing with 2* 80W solar panels that boosts power generation efficiency of 25%, making it a budget-friendly option.
Power On The Go: Quick setup. The foldable handle is designed for easy transportation, plus it saves more space. The upgraded 80W solar panel achieves an IP68 waterproof rating, making it extremely fit for outdoor exploration & power outages.
All-Round Safety: Pure sine wave inverter delivers stable power that protect equipment from damage. Works quietly (46dB), the product also features a battery system (BMS) for ultra-long battery life. The adjustable LED light is made to satisfy your outdoor needs.
Dual 100W PD Design: 2* USB-C & 2* 100W PD ports, delivering steady power for essentials such as phones, iPads, laptops, drones. Featuring multiple ports – 1* 800 AC input port, 3* 1000W AC output ports, 1* USB A and DC car port.
Ultra-Long Standby: Supports up to 1000 charge cycles and the low self-discharge rate allows it to last 365 days from an 80% battery level, making it excellent company for off-grid living and power outages.
