Price: $12.50
(as of Aug 14, 2024 12:15:19 UTC – Details)
1 pack 500ml Double Walled Coffee Mug,Insulated Stainless Steel Tea Cups,Metal Milk Mug with Handle,Double-Layer Insulation Function Juice Cold Drink Cup,Travel Camping Mug
Double Walled Stainless steel 304# Coffee Mug
(1)Material: stainless steel 304#
(2)Maximum Capacity:500ml.
(3)Diameter:3.34 inch (8.5cm)
(4)Height:4.92 inch (12.5cm).
(5)Weight: 260g/0.57 lbs
NOTE:
This mug is only designed to hold beverages.
It can neither be directly heated nor used as any cooking tool.
Double Walled Stainless steel 304# Coffee Mug——Application scene(1)
Widely Use:Suitable for tea, coffee, milk, juice, beer and other beverages.
Double Walled Stainless steel 304# Coffee Mug——Application scene(2)
Lightweight and Durable:
Double-walled design provides insulation while reducing weight.
Stainless steel material, more impact-resistant, not easy to break.
Therefore, lighter and more durable.
500ml Double Walled Stainless steel 304# Coffee Mug——Material and Manufacturing Process
Double Wall Design:Double walled construction keeps hot things hot and cold things cold longer than ceramic cups,significant heat preservation effect
Double Walled Stainless steel 304# Coffee Mug——Manufacturing Process
(1) Mug with handle.
(2) Smooth edges.
(3) The outer surface of the mug adopts stainless steel mirror polishing process.
Double Walled Stainless steel 304# Coffee Mug——The overall appearance of the mug
(1)Size
Diameter: 3.34 inch (8.5cm)
Height: 4.92 inch (12.5cm).
Weight: 260g/0.57lbs
(2)Package List: 1 x 500ml Mug
Product Dimensions : 3 x 3 x 3 inches; 9.17 ounces
ASIN : B0BD1XH7QL
Country of Origin : China
(1)Material:It is made of 100% 304 (18/8) food grade stainless steel,Have a smooth mirror finish on the surface,Dishwasher safe.
(2)Double Wall Design:Double walled construction keeps hot things hot and cold things cold longer than ceramic cups,significant heat preservation effect
(3)Lightweight and Durable:Compared with glass cups and ceramic cups of the same capacity, it is lighter in weight, but more durable, anti-drop and anti-collision, and can be used continuously for more than 5 years.
(4)Widely Use:Suitable for tea, coffee, milk, juice, beer and other beverages.
(5)Maximum Capacity:500ml.
(6)Diameter:3.34 inch (8.5cm)
(7)Height:4.92 inch (12.5cm).
(8)Weight: 260g/0.57lb
(9)Package List:1 x 500ml Mug
