Price:
(as of Sep 04, 2024 09:30:13 UTC – Details)
2 Pieces 400ml Double Walled Coffee Mug,Insulated Stainless Steel Tea Cups,Metal Milk Mug with Handle, Travel Camping Mug
Information of the mug at a glance
Material: Stainless steel 304#.Advantages of double-wall design: Double-layer structure has heat insulation function. The heat preservation effect is remarkable. Lighter weight and more durable. Anti-fall and anti-collision, can be used continuously for more than 5 years. Scope of application: Suitable for cold drinks and hot drinks. For example, tea, coffee, milk, juice, beer and other beverages.Applicable occasions: Kitchen/Dining bar/Camping/Travel.Full load capacity: 400ml.Number of cup: 2 pieces
Size details
Widely Use: Suitable for tea, coffee, milk, juice, beer and other beverages.
Cross-section of the internal structure of the cup
Advantages of double-layer design
Insulation and heat preservationReduce weight, the cup is lighterAnti-collision and anti-fall, not easy to break
Workmanship Quality & Scope of Application & Applicable Occasions
Craftsmanship and quality
Mirror polished outer surface.Round handle.Smooth edges, no burrs.
Application scope of mug
Suitable for cold and hot drinks.Suitable for tea, coffee, milk, juice and other beverages.
Suitable occasions for mugs
Kitchen Bar Party Camping Travel
125
125
4.3 out of 5 stars
32
3.1 out of 5 stars
5
4.0 out of 5 stars
7
4.7 out of 5 stars
21
$11.99$11.99 $10.50$10.50 $12.20$12.20 $12.80$12.80 $14.50$14.50 $18.50$18.50
Material and structure of the cup
Stainless steel 304# & Double Wall Structure Stainless steel 304# & Double Wall Structure Stainless steel 304# & Double Wall Structure Stainless steel 304# & Double Wall Structure Stainless steel 304# & Double Wall Structure Stainless steel 304# & Double Wall Structure
Full load capacity
500 ml 400 ml 210 ml 280 ml 400 ml 500 ml
Quantity of Cup
1 piece 1 piece 2 pieces 2 pieces 2 pieces 2 pieces
Cup Handle Shape
Flat handle Round handle Round handle Round handle Round handle Flat handle
▓ ▓ 【Material&Structure&Application】▓ ▓
▓(1)Material and manufacturing process: high quality stainless steel 304#. The outer surface of the cup is mirror-polished, making it smooth and easy to clean.
▓(2)Structure and advantages: double-wall structure. It is insulated without being hot to the touch, and also has a certain heat preservation effect. The cup is lighter. It will not be damaged even if it is dropped or bumped.
▓(3) Scope of application: Suitable for cold drinks and hot drinks. Such as milk, coffee, juice, soda, tea, etc.
★★★【List of Important Information about Mugs】★★★
★(1) Dimensions and cup net weight: Height is 4.13 inches/10.5 cm, diameter is 3.2 inches/8.2 cm, single cup weight is 160 grams/0.35 pounds.
★(2)Maximum volume: 400ml
★(3)Package includes: 2 pieces
