Insulated Stainless Steel Coffee Beer Mug/Double-Wall Camping Travel Coffee Stainless Steel Cup/Double Wall Vacuum Travel Metal Hot Mug/Tumbler Mug/Shatterproof Cup.210ml,2Pieces
Price: $12.95 - $12.20
(as of Sep 04, 2024 15:15:24 UTC – Details)
2 Pieces 210ml Double Walled Coffee Mug,Insulated Stainless Steel Tea Cups,Metal Milk Mug with Handle, Travel Camping Mug
insulated mug with handle,double walled mug,metal mug,stainless steel coffee mug with handle
Information of the mug at a glance
Material: Stainless steel 304#.
Advantages of double-wall design: Double-layer structure has heat insulation function. The heat preservation effect is remarkable. Lighter weight and more durable. Anti-fall and anti-collision, can be used continuously for more than 5 years.
Scope of application: Suitable for cold drinks and hot drinks. For example, tea, coffee, milk, juice, beer and other beverages.
Applicable occasions: Kitchen/Dining bar/Camping/Travel.
Full load capacity: 210ml.
Number of cup: 2 pieces
Size details
Widely Use: Suitable for tea, coffee, milk, juice, beer and other beverages.
Cross-section of the internal structure of the cup
Advantages of double-layer design
Insulation and heat preservation
Reduce weight, the cup is lighter
Anti-collision and anti-fall, not easy to break
Workmanship Quality & Scope of Application & Applicable Occasions
Craftsmanship and quality
Mirror polished outer surface.
Round handle.
Smooth edges, no burrs.
Application scope of mug
Suitable for cold and hot drinks.
Suitable for tea, coffee, milk, juice and other beverages.
Suitable occasions for mugs
Kitchen
Bar
Party
Camping
Travel
125
125
4.3 out of 5 stars
32
3.1 out of 5 stars
5
4.0 out of 5 stars
7
4.7 out of 5 stars
21
$11.99$11.99
$10.50$10.50
$12.20$12.20
$12.80$12.80
$14.50$14.50
$18.50$18.50
Material and structure of the cup
Stainless steel 304# & Double Wall Structure
Full load capacity
500 ml
400 ml
210 ml
280 ml
400 ml
500 ml
Quantity of Cup
1 piece
1 piece
2 pieces
2 pieces
2 pieces
2 pieces
Cup Handle Shape
Flat handle
Round handle
Round handle
Round handle
Round handle
Flat handle
(1)Material:Food Grade Stainless Steel 304#
(2)Craftsmanship: Mirror polishing on the outside of the mug
(3)Double Wall Design:Double walled construction keeps hot things hot and cold things cold longer than ceramic cups,significant heat preservation effect
(4)Lightweight and Durable:The double-wall structure not only has a more significant thermal insulation effect, but also has a lighter weight, is anti-fall and anti-collision, and can be used continuously for more than 5 years
(5)Multifunction:Suitable for hot and cold beverages such as milk/coffee/juice/tea
(6)Maximum Capacity:210ml
(7) Height:3.14inch (8cm)
(8) Diameter:2.7 inch (7cm)
(9)Weight: 101g(0.22lb)
(10)Package includes: 2pcs 210ml mugs
