Impact Grade Driver Sockets Adapter Extension Set Drill Bit 3Pcs 1/4 3/8 1/2″ Universal Socket Adapter Set and Right Angle Drill 105 Degree Right Angle Screwdriver set Drill Hex Bit Socket Adapter
Price: $12.99
(as of Sep 26, 2024 12:45:20 UTC – Details)
①Package Included
1 x (1/4″ hex shank to 1/4″ socket)Socket Adapter
1 x (1/4″ hex shank to 3/8″ socket)Socket Adapter
1 x (1/4″ hex shank to 1/2″ socket)Socket Adapter
1 x 105° Angle Drill Adapter
②Angle power extension
1/4″ Hex shaft screwdriver extension, convenient, durable, long lasting and easy to use.
It’s good for wrench and power drill, rechargeable drill or manual wrench.Light weight, fast, connect to the standard hex screwdriver.
Functional head has locking & magnetic function, 105 Degree right angle head.
Specifications
Material:Vanadium chromium steel Stainless Steel
Size: 5.9 X 3cm
Color:Black
torque capacity: 16N. It only allows for a 1/4 hex bits
③About 1/4-Inch Drive Drill Socket Adapter/Extension Set
Suitable for Quick Change 1/4″ Chuck Systems or Directly into Drill Chuck.
Turns any power/cordless drill into a power nut driver.
Handy for Fast Driving of Nuts, Bolts and Fixings, etc.
Spring Loaded Ball Bearing on Head Holds Sockets Securely.
Widely used in home DIY, carpentry, auto parts, specializing in machine repair and so on.
Specification :
Weight: Approx.100g
All Sockets Standard 1/4″ Hex Shank
Size:
1/4 * 1/4 * 65mm length — 1/4 ” shank can be converted to 6.35mm square head
3/8 * 1/4 * 65mm length — 1/4 ” shank can be converted to 9.4mm square head
1/2 * 1/4 * 72mm length — 1/4 ” shank can be converted to 12.6mm square head
🚫 NOT FOR impact drill
⚠ Note: Please adjust the torque to a minimum when using the electric screwdriver. Do not rely on it to tighten the screws if the hand drill is used. Finally, you must tighten the angle driver adapter manually, or the gear will be broken off.
☆【Multifunction] 3Pcs1/4 3/8 1/2″Square Nut Hex Shank Driver Drill Bit Used in the installation of pneumatic screwdriver, electric screwdriver, pneumatic drill, manual screwdriver and other installation for the hexagonal tool .It is a good accessory for conversion. for Universal Socket,Impact Adapter and Reducer Set,Universal Joint Set,Socket Adapter and Drive Reducer Set,Drive Impact Socket Extension Bar Set,Drive Impact Socket Set.
☆【Wide application】105°Right Angle Drill Driver Can be connected to the drill, rechargeable drill or manual wrench, extending their reach to inaccessible stenosis , twisting screws, nut and more.
☆【Features】105° designs for tight spaces, extends the power of a cordless screwdriver – 100 in/lbs. torque, 400 RPM.These Tools are Work Great for Light Drilling,Slow Speed/Screw Driving,Like Cordless Drill,Ratchet Hand Screwdriver,etc.
☆[High Quality] 105°Angle Extension Made of Chrome Vanadium steel, high hardness angle drill bit holder, anti rust, durable die cast body with 3 ball bearings for long life [Strong Magnet] Built in strong magnet for good holding power, this right angle drill attachment is easy to use and avoid falling off [Easy To Use] 105 degree angle extension, 360° parallel adjustment, perfect handy tool for hard-to-reach corners and tight spaces, max torque 15n/m.
☆【Warranty】: Hello, welcome, you have worked hard! Thank you for choosing our product. If the product has any quality problems within 2 years, please feel free to contact us before making an evaluation. We will give you a full refund. Thank you for your cooperation. We offer 24 hours customer service to convenient for customers.
