Price: $289.99 - $1,399.00
(as of Aug 26, 2024 13:15:12 UTC – Details)
Magnetizable Iron Shell Refrigerator
ICECO VLPro DUAL ZONE Series
This independent control of the dual zones gives you the flexibility to use the refrigerator in four modes (one freezer and one refrigerator, and freezer/refrigerator at the same time). You can even use one zone separately to save power. The multi-directional lid design allows you to use the refrigerator in the trunk while the car is parked, and also allows you to conveniently take food from the refrigerator directly in the car while driving. No need to move the refrigerator repeatedly!
Design Details Convenient Drain
Convenient to clean after use. A replacement plug is also included in the package. Easily take care of your refrigerator to keep it clean.
Built-in LED Light
Built-in LED light makes it easy to distinguish the foods of the freezer even in poor light environment. Auto-sensing design!
Spring-loaded Handle
Stainless Steel Ring Pull Handle designed with the spring auto-rebound. Can be repeatedly installed and disassembled.
Large Vents
Waterproof ventilation openings are provided on both sides of the compressor. Allows air circulation to keep compressor working continuously.
1 Reversible Lid 2 Independent DualZone 3 DC+AC+USB ports
1 SECOP Compressor 2 Max&Eco Mode 3 32dB Low Noise 4 3Level Battery Protection 5 40° ANTI-SHAKE
Magnetic Battery
Product Exhibition Gallery
Is it normal for a refrigerator to have temperature fluctuations while it is cooling?
Yes, it is. Because the refrigerator compressor has energy-saving characteristics, the compressor will stop working to keep warm when it reaches the set temperature. After a period of time, the compressor will work again for refrigeration.
What is the function of triple batteryprotection? How do they work?
The triple battery protection is designed toprevent over-discharge and battery depletion.When the measured DC voltage is below theset value, the compressor is shut off to preventbattery depletion.
Why is the temperature on the refrigerator display different from the temperature I measured with my thermometer?
Because of the sinking nature of cold air, the different temperatures may exist in different locations in the refrigerator (the temperature of the bottom will be the lowest). The panel only shows the average temperature of the refrigerator.
What if the refrigerator is upside down when we receive it?
Please leave refrigerator upright and empty for 24 hours to allow compressor lubricant to resettle before powering on it. Let the fridge operating several days to see whether it’s working properly. If there’s any problem please reach to us for help.
If I place an order, how long will the order be processed and why is there no logistics information for my product?
The processing time is usually 1 working day. If the logistics statu shows “label created”, it may be a shipping update delay of the carrier company, please be patient. And your Amazon messages will be answered within 24 hours including on weekends.
Multi-opening Lid Design – You can change the opening direction of the lid without assembly. Access to cold storage can become very easy even in the tight space inside a traveling vehicle.
Independent Dual Zone – This car refrigerator has a cooling range of 0-50℉ and both zones can be controlled and used independently. You can use one zone as a freezer/refrigerator, both zone for freezer/refrigerator, or even close one zone and only use one zone to save energy! All depends on you! 95Qt capacity is perfect for RVing
Humanized Design – Designed with drain hole, waterproof baffle, LED lights and removable handles. The package also comes with removable basket, replacement handles, corner protectors and drain plugs. With portable power station, it will greatly increase the using time and protect your food keep cool.
SECOP Compressor – ICECO VL90ProD car freezer use SECOP Compressor to ensure stable and superior performance. MAX mode for fast cooling and ECO mode for energy saving; Ultra-quiet cooling system, will not bother you at any time. Multiple function to protect the freezer: 40° Anti-Shake technology; L/M/H 3-level battery protection to prevent car from running out of power.
Warranty & Services – This car freezer comes with 5-Year warranty on the compressor and 1-Year warranty on all other parts. ICECO has professional technical support team, LA Local after-sales service and Telephone service; Your messages will be answered within 24 hours including on weekends, giving you a great experience!
