Price: $849.00
(as of Aug 23, 2024 15:45:26 UTC – Details)
Product Detail Latch
The latch makes the refrigerator lock tighter, avoiding the leakage of cold air and improving the sealing performance and refrigeration efficiency.
Handle
Elastic iron handle, thin but strong, can better save space and make it easy to move.
LED Light
The LED light can always be on when the refrigerator opens and then automatically off after closing the refrigerator, which is more energy-efficient.
Upgraded Hinges
Metal hinges had better ability against shear forces and stress. After many times of opening and closing can maintain normal use.
SECOP Function Details 40° Operation
The SECOP compressor keeps the refrigerator working steadil, even under 40° tilt, which is perfect for off-road trips.
Low Noise
SECOP compressor keeps the refrigerator running steadily, keeping quiet and not interfering with life and work.
3-Level Battery Protection
With the SECOP compressor, the portable refrigerator can shut down properly before the car battery runs out.
MAX And ECO Mode
Installed with SECOP compressor, refrigerators can get cool or frozen quickly with MAX mode and then you can choose the ECO mode for energy saving.
Product Exhibition Gallery
ICECO Related Products
4.7 out of 5 stars
1,449
4.7 out of 5 stars
412
4.5 out of 5 stars
63
4.5 out of 5 stars
68
4.5 out of 5 stars
836
$849.00$849.00
$999.00$999.00
$999.00$999.00
$859.00$859.00
$599.00$599.00
$449.00$449.00
Temperature Range
0℉-50℉
0℉-50℉
-4℉~68℉
-4℉~68℉
0℉-50℉
Unit Capacity
63.4 Quarts | 60 Liters
1075Wh
79.2 Quarts | 75 Liters
58 Quarts | 55 Liters
21.1 Quarts | 20 Liters
Dimensions inch (L*W*H)
31.2*19.5*18.9”
14.2*10.3*10.5
38.3*18.3*18.1”
29.7*18.9*19.3
28.5*13.8*21
22.4*12.6*12.4
Rated voltage
AC 110-240V | DC 12/24V
Weight (lbs)
65.7
32.5
67
54.7
45.8
25.5
Including Cables
DC & AC Cables
AC & Soalr Panel Cable
DC & AC Cables
DC & AC Cables
DC & AC Cables
DC & AC Cables
Flexible Dual Zone
SECOP Compressor Brand
Independent Control – Dual zone and independent controlling allow you to use freezing and refrigeration in any combination (freezer & refrigerator, both freezer, or both refrigerators). Moreover, you can choose to turn off one zone for the purpose of energy saving.
SECOP Compressor – Cooling range from 0°F to 50°F(-18℃~10℃) to meet all your freezing or refrigeration need. Fridge cooling rate can be selected between MAX mode for fast cooling or ECO mode for more energy efficiency. SECOP Compressor makes the car refrigerator keep running well even under 40° tilt.
Car and Home Use – Each portable refrigerator is equipped with a DC cord and an AC cable. Independent 12V/24V DC and 110-240V AC output port avoid chaotic wire accumulation and make the use environment cleaner and safer.
User-friendly Design – Height design fit for tonneau cover of pickup truck. Metal shell, thickened inner wall and foldable pull-down lock provide good insulation conditions. Convenient interior lights for easy access in the dark. Two Removable wired baskets to allow quick emptying and restocking of the fridge.
Warranty – 5 year warranty on the compressor and 1 year warranty on all other parts. Customer service phone line is available and your Amazon messages will be answered within 24 hours including on weekends.
