Hikity Backup Camera with Monitor Kit, Waterproof 18 IR LED Night Vision Reverse Camera + 7″ Rear View Monitor Vehicle Parking System for RV Bus Trailer Truck (65ft 4-Pin Aviation Video Cable)
Price: $69.99
(as of Sep 18, 2024 06:00:34 UTC – Details)
hikity backup camerahikity backup camera
Special thick hard ware can shield vehicle circuit interface. Silicone case to prevent weathering corrosionUpgraded Backup System Loaded with Advanced Features – Complete backing camera with clear monitor and all the essential accessories for easy DIY plug & play installation.
rv backup camerarv backup camera
With 18 infrared lights, the camera will provide HD night vision images for you. rear view camerarear view camera
Parking Lines Assistance will make your parking safer and faster.If you don’t need it, you can turn off it via Menu or disconnect the green wire. 7 inch backup monitor7 inch backup monitor
7-inch LCD screen provides colored and vivid images with more detailsThe bright color display technology restores the colors of the real world dual backup cameradual backup camera
choose ASIN B0B924Z2NJ to gect second cameraWhen you want to see another camera, just press the “V1/2” button.
reversing camerareversing camera
The camera uses a unique potting process to achieve an amazing level of waterproofing.No need worry about driving in the rain or bad weather. mirror cameramirror camera
The Multiplexer Controls The Camera View Between a Mirror Image And a Normal Image. Image can also be inverted. Choose freely in settings. waterproof camerawaterproof camera
The New Upgraded One Has a Perfect Viewing Angle Design of 170°, Further Improving The Vision with Better View-Scale.
AHD cameraAHD camera
The lens of the camera can be adjusted up and down, allowing you to view from different angles.
backup camera kitbackup camera kit
It contains two cables for two cameras, you can ask us for the more cables if you need.If you want to view the instructions before purchasing, please reach us, we are willing to provide you.
【Hikity Backup Camera Monitor Kit】7″ Color TFT LCD Monitor + 18 IR LED Night Vision Reverse Camera + 4 Pins Connector Cable. Hard wired connection guarantees safe and clear and stable reversing image. Reverse camera with monitor comes with remote controller and Stand
【7-inch Screen Car Rear view Monitor】2-channel video input, high resolution image, full color display and low power consumption, adjustable brightness, contrast and color. Image can be rotated horizontally and vertically for mirror or normal viewing
【IP68 Waterproof RV Backup Camera (No Guide Lines)】Hard Metal Cased Camera, waterproof and Mud proof. 18 IR LEDs for Night Vision + 120° horizontal wide view angle + 180°vertical adjustable angle to view the blind spots. You can get it work Full Time when connect to constant power source
【Extended Aviation 4 Pins Connector Cord】Strong anti-interference, more close connection, easy to install. Special thick hardwire can shield vehicle’s circuit interference better than normal AV cable
【Wide Comatability】Voltage Range From 12-24V DC Power to Accomodate a Wide Variety of Large Vehicle as Truck, Bus, RV, Tractor, Car and ect
【After-sales Service & Technical Support】Please check if the power cable port on the detail page matches your car before purchase. We provide 30DaysMoneyBack, 12MonthsReplacement and life-time Technical Support. If you have any problems with installation or use, please click the seller’s name on the product page: Ohradio-Ask-a-question-Send message to seller, we will reply-within-24-hours to help you solve the problem
