Price: $115.99
(as of Aug 08, 2024 10:30:32 UTC – Details)
4 Channel 1080P HD Camera with DVR Recorder Monitor System For RV Semi Box Truck Trailer Motorhome
DALLUX HD 1080P Truck Bus Backup Camera with 9 inch DVR Recorder Monitor System
This HD 1080P backup camera system is complete with a crystal clear 9″ DIGITAL IPS LCD color monitor built-in DVR recorder,it supports record 4 channels camera at the same time and loop recording. The storage capacity can up to 256GB, it can be adjust mirror image and rotate image.145° SONY 1/3 inch Color CCD 1080P reverse/front/side view camera with 50 foot infra-red night vision. The rear view camera is completely weatherproof with an IP69K rating, strong and reliable, shock resistant, with a 20G vibration and 100G impact rating (highest in the industry).
This RCS9000Q Camera system can be use on Bus, Truck, Van,Trailer, RV, Campers, Motor Home, School bus, Pickup Truck,Travel Trailer, Oversized Truck, Dump Truck, Camping Trailer, 5th(fifth)wheel RV, Excavator, Horse Trailer and Agricultural Machine in farm for 360 degree view vision monitor, vivid image and excellent night vision function provide drivers a safety driving in date time and night time.
DALLUX Digital Built-in DVR Monitor Specification
9 inch digital color LCD monitor Resolution: 1024*RGB*600Video System: PAL/NTSC autoPower: DC12V-24VPower consumption: about 6WVideo: 4 video inputsMaximum Storage Capacity: 256GB
DALLUX High Definition Rearview Camera Specification
Image Sensor: 1/3 “SONY Color CCDResolution: 1080POperating voltage: 12V-24VOperating temperature: -20~80 degree centigradeOutput cable: 4PIN aviation connectorWaterproof Rate: IP69K
HD 1080P Backup/Front/Side View Camera With DVR Recorder Quad Split Monitor System
Super Sharp Natural Color Image
Backup camera built-in 1/3 inch color CCD image sensor. HD 1080P resolution, 1/3 inch image sensor unit pixel area is bigger than 1/4 inch, so the image quality is better, CCD better than CMOS image sensor on sensitivity, resolution and noise control, complete with 1024*RGB*600 digital IPS monitor, it can give you a pretty sharp natural color image.
Waterproof IP69K Rating
Backup camera comes with patent design casing, special waterproof glued process. Completely waterproof with an IP69K rating. This is actually the highest IP rating there is and means the camera will work fine in all weather conditions such as pouring rain & violent storms.
145 degree Viewing Angle No Blind Spot
Backup camera comes with 6 layer glasses high definition lens, with an ultra wide 145°viewing angle, the backup camera will provide a complete view from behind your vehicle. This ensures complete safety with no blind spots.
HD 1080P Backup/Front/Side View Camera With DVR Recorder 4 Split Screen System
Switch Parking Line ON/OFF and Flip Screen Image
The menu on LCD monitor can adjust the camera with or without the parking assistant line, as well as flip screen image between a mirror view image or a front view image. This allows the connected cameras to be used either as backup or forward facing cameras.
Built-in Powerful DVR Recorder
This 9 inch Quad Split Screen LCD monitor built-in DVR recorder, it’s maximum storage capacity is 256GB, it supports record 4 channels camera at the same time and loop recording. Durable and reliable camera system help you driving/reversing more confident.
Package Content
Package Included:
1 x 9 inch Monitor, 4 x CCD Reverse Camera,
1 x Remote Controller, 2 x Mount Bracket,
1 x Monitor connect cable, 2 x 66 feet 4 Pin aviation Camera Extension Cable,
2 x 33 feet 4 Pin aviation Camera Extension Cable, 2 x Screw Kit, 1 x User manual
【Widely Compatibility】This backup camera system supported 12-24V power input.Can be wired for backup (reverse) or constant power.The best choices of backup camera system for RV,Trailer,Truck,Camper,Van,Motorhome,5th wheel,Tractor,Pickup,Semi Truck, School Bus, Cargo Van.
【360° Full View Image】It comes with 9 inch IPS panel all viewing angle screen,this monitor can split to Full/Dual/Three/Quad screen, mirror image and rotate image. 360 degree viewing to avoid blind spot, makes it more convenient and safety for driving.
【Powerful Recording】 Built-in DVR monitor, it supports record 4 channels camera at the same time and loop recording. The storage capacity can up to 256GB, saving the video automatically just in case,so we can find the video easily if we need. ARM DSPS High speed processor give you a better vision experience. Built-in Linux operating system help us to operate more conveniently.
【Excellent backup camera】Rear/front view and side view IR night vision camera with high definition 1080P 1/3″ CCD image sensor,6 layer glasses HD lens, 145 degree wide viewing angle, IP69K waterproof camera can withstand -68°F~176°F extreme temperature and work well even in heavy rain or other bad weather condition. Durable and reliable camera system help you driving/reversing more confident.
