Heated Bento Box Electric Lunch Box Portable Food Warmer Heating Lunch Box Lunch Heater for Car&work Leak Proof 12V 24V110V 3 Grid Plate Removable Container for Adults with Carry Bag (White)
Price: $29.99
(as of Aug 17, 2024 02:30:14 UTC – Details)
NICEPRO Electric Lunch Box
Electric Lunch BoxElectric Lunch Box
12-24V/110-240V -Support 12V car use + 24V truck use + 110-240V work use.
For those who do not have a microwave in the studio and often work outdoors, such as car/truck drivers, construction workers, office workers, now with this electronic lunch box, you can heat your lunch anywhere and anytime.
Easy to cleanEasy to clean
Power indicator at a glancePower indicator at a glance
3 Grid Plate- separate meals without smell3 Grid Plate- separate meals without smell
Sealing ring + 4 buckles = no water leakageSealing ring + 4 buckles = no water leakage
Easy to clean
The 304 stainless steel container is removable, easy to clean and dishwasher safe.
12-24V/110-240V, as long as there is electricity, it can be used.
Made of 304 stainless steel and food grade PP material, high-temperature resistant, non-toxic, durable and safe to use
Electric lunch box with sealing ring improves the defect of food leakage
Well-designed large-capacity handbagWell-designed large-capacity handbag
In addition to storing lunch boxes, the well-designed large-capacity handbag can also contain fruits, milk, beverages, sun umbrellas, etc., to solve your travel troubles
Separate design
Leak-proof Food Grade PP, without BPA
Removable 304 Stainless Steel Tray
Easy to Use with 3 Compartments
Support 12V car use + 24V truck use + 110-240V work and home use.
60W safe Heating
Package Includes 1 x Electric Lunch Box 1 x Sealing Ring (Installed on the lid) 1 x Spoon 1 x Fork 1 x Large-capacity handbag 1 x Car-use Cable -12-24V 1 x Home-use Cable-110-240V 1 x Manual
Cable 12V for car and trucks useCable 12V for car and trucks use
Go for a picnicGo for a picnic
Office/home useOffice/home use
Car and truck use
Electric Lunch Box Support 12V-24V Cars, Trucks, you can heat your food on the go. Perfect for cab driver, freight drivers to enjoy healthy and warm food.
Great for picnics and family trips
You can take your favorite healthy food with you during an outdoor picnic. That is perfect!
Office/home use
Cable 110-240V for home, office and school use, no more wait in line for microwave heating, you can have a warm meal sitting in your seat.
Method of use
(A) Heating food
1.Please put the cooked food into the rice container and the dishes container.
2. Please fasten the lip.
3.Open the socket shopper, insert the power cord.
4.Switch on the power, the power indicator light, plus soup began.
Note:Heating time depends on the amount of rice, vegetables.
and the indoor temperature.
(1)Heating food just need 25 minutes on the condition of 25 degrees centigrade.
(2)When the food get from the fridge, the heating time should be extension appropriate
(3)Please pull out the power cord before eating
(B)Heating soup
1.Please put the cooked soup into the lunch box.
2.Please fasten the lip.
3.open the socket stopper, insert the power cord
Note: Heating time depends on the amount of rice, vegetables, and the indoor temperature.
(2)When the food get from the fridge, the heating heating time should be extension appropriate.
(3)Please pull out the power cord before eating.
【Wide Application Range】 Socket + car cigarette lighter two power supply modes: 12-24v ,110-240v, as long as there is electricity, it can be used, and you are not afraid to travel all over the world.
【Rapid Heating】: Improve food warmer, no longer wait, finish heating in 20 minutes, and enjoy delicious hot meals.
【Safe Constant Temperature Heating】: NICEPRO lunch containers will automatically keep warm when heated to 60°C. It will not overheat and wait for a meal, and it will not burn and damage the equipment. It is safer and more worry-free to use.
【Good Sealing】: Sealing ring + buckle = no water leakage even if it is inverted, which solves your worries when using.
【Lunch Boxes For Adults】: The large compartment can hold enough food for adult men, so you don’t need to worry about not having enough food.
