HD Wired Backup Camera System Kit, Sharp CCD Chip, 100% Not Wash Up, IP69 Waterproof Rear View Camera + 7’’ LCD Monitor Reversing for Truck/Semi-Trailer/Box Trucks/RV (ERY01)
Price: $369.98 - $129.99
(as of Aug 11, 2024 08:00:26 UTC – Details)
ZEROXCLUB ERY01 Wired Backup Camera System Kit ERY01ERY01
ERY01ERY01
ERY01ERY01
ERY01ERY01
ERY01ERY01
If you want to learn more about the instructions before purchasing, please reach us.
ERY01ERY01
If you find that an accessory is missing or damaged, please find us for a replacement.
ZEROXCLUB Wired Backup Camera System: Trusted by Millions of Customers!
The Compatible camera
B082HKJ4XC (Rear View)
B0BG7Z3Z47 (Rear View),B0BG7Y2DD2 (Side View)
IP69k Waterproof
It is tested to withstand the tough conditions in heat, cold, rain, or sun.
IP69k Waterproof
IP69k Waterproof
Capture clearer details
See more behind the vehicle with 720P and 149º wide viewing angle.
See more behind the vehicle with 1080P and 170º wide viewing angle and recording
See more behind the vehicle with 1080P and 149º wide viewing angle and recording
Clear Night Vision
Equipped with 18 pcs infrared LED and gives 720P high resolution images
Clear Night Vision
Equipped with 18 pcs infrared LED and gives 1080P high resolution images
Clear Night Vision
Compatible Vehicles
RV/Camper/Truck/Trailer/5th Wheel Trailer/Bus/Van/Motorhome/Farm Mach/So on
Compatible Vehicles
Compatible Vehicles
[HD 720P&Safety] 720P provides you with real, vivid and colorful images, 7 Inch LCD monitor bring high picture quality and clarity, so you can see the environment behind car more clear. You could confidently back up and do not worry about the people who walking behind your moving vehicle with their heads down texting!
[No interference&Easy To Use] Due to the backup camera being hard wired and CCD sensor,the images are not blurry and no interference.You can adjust color, brightness, hue as per your like. And you can also flip the picture upside down if you want too.
[IP69K warterproof&Night Vison] The Rear Camera is in a metal housing and with an IP69 waterproof, you don’t worry about water or dirt intrusion. The ZEROXCLUB Reversing Camera support 2 cameras, which allow you to add an additional camera CM-ERY01(B082HKJ4XC) and you can switch views at will. Equipped with 18 LED infrared lights, it can also be seen clearly at night.
[Easy Installation] You could string the cable even in the long distance, and the backup camera system came with everything needed for installation. Connect the camera cable to the yellow 4 pin connector, and the red wire is connected to the positive pole/constant power; black wire is connected to the ground/negative pole; green wire is connected to the reverse light(parking lines).
[Customer Service&Applicable vehicles] ZEROXCLUB offer 18-month warranty to each of our customers from the date of purchase, any questions please contact us anytime, we will get back to you within 24 hours. Wired Backup Camera with 50 foot camera extension cords for RV/Camper/Truck/5th Wheel/Trailer/Bus/Van,and more. The 4 pin “aircraft cable” for rear view camera is a higher grade,with Longer Service Life.
