Price: $47.99 - $28.99
(as of Sep 26, 2024 13:00:36 UTC – Details)
GreenYi HD Backup Camera with Adjustable Lens
The video showcases the product in use.The video guides you through product setup.The video compares multiple products.The video shows the product being unpacked.
This backup camera’s body can be rotated for 360 degrees, its lens can be rotated for 45 degrees(right to left) + 45 degrees(up to down), you can get a perfect view with all kinds of position installation. There is an extra silicone holder included in case you don’t want to drill a hole.
Features of Car Rear Camera IP68 Waterproof
GreenYi waterproof backup camera can work properly under most bad conditions, no need to worry about fost, water or mist getting into it.
Starlight Night Vision
Backup camera for car has a good performance even when reversing at dark night, high clarity sharp colorful image will still show on your monitor.
Double-shielded Video Cable
GreenYi backup camera comes with 26FT / 8M long video cable, enough for most vehicles. Double-shielded design to ensure high quality video signal.
4Pin Backup Camera for Car
4pin design, easier installation than that of RCA. Can’t be connected to any dashcam, mirror cam or GPS monitors that does not support RCA video input
Three Holders for Selection(Holder 3 needs to buy separately):
Holder 1: The backup camera comes with this metal holder installed well by default. You can install it with horizontal or vertical(upside down) mounting.
Holder 2: If you don’t want to drill a hole on your vehicle, you can apply this silicone holder. Insert the round camera body into the silicone holder, then you can install it with ease.
Holder 3: This metal holder is for flush hidden mounting, need to drill a hole. Need to buy separately with ASIN: B0BLG78TTM.
About GreenYi Vehicle Backup Camera:
NOTE: All of our 4pin backup cameras can’t be connected directly with any other monitors(no matter DVR or dashcam or whatever) which is not compatible with RCA video input.
* Please test the back up cameras before final installation.
* If there is no option for AHD 720P 30HZ/NTSC in your video signal settings page of your monitor, then please don’t cut the orange cable.
* If you connect the backup camera for pickup to a FACTORY RADIO, please order a suited Harness & Programmer separately, because different RADIO needs different Harness & Programmer.
* There is a pink color wire on your head unit usually, please connect it with the 26FT video cable’s trigger wire.
* Before you routing, if there is no image on the screen, other than check the camera, please check display settings as well. You can use other device with RCA connector, such as TV to check if the camera works.
Package:
1. 1 * HD 720P Backup Camera 2. 1 * 26FT Double Shielded Video Cable 3. 1 * 5FT Power Cable 4. 1 * Metal Holder set 5. 1 * Accessory Bag for Metal Holder 6. 1 * Silicone Holder
7. 1 * Accessory Bag for Silicone Holder 8. 1 * User Manual 9. 1 * Adhesive Tape 10. 1 * Removal Tool 11. 5 * Zip Ties 12. 5 * Wire Clamps 13. 1 * Mini Screwdriver
14. 1 * Electric Adhesive Tape 15. 2 * T-tap Sets
Specifications
Image Sensor CCD AHD Chip Power DC 12-24V Resolution 1280*720 Pixels Viewing Angle 170 degrees Waterproof Grade IP68 Minimum Illumination 0.01Lux / F1.5 TV System NTSC Signal to Noise Ratio ≤48dB Working Humidity 80%RH Operating Temperature -22℉— +140℉ Storage Temperature -40℉—+176℉
Compromises Other Backup Cameras’ Advantages:
4.2 out of 5 stars
461
4.2 out of 5 stars
72
3.7 out of 5 stars
68
4.8 out of 5 stars
10
3.8 out of 5 stars
26
4.1 out of 5 stars
23
4.0 out of 5 stars
37
$28.99$28.99
$30.99$30.99
$31.99$31.99
$39.99$39.99
$36.99$36.99
$39.99$39.99
$59.99$59.99
Adjustable Camera Body
Resolution
1280x720p
1280x720p
1920x1080p / 1280x720p
960x720p
960x720p
1280x720p
Viewing Angle
170 Degrees
170 Degrees
170 Degrees / 120 Degrees
170 Degrees
170 Degrees
130 Degrees
Support Guideline on / off
Vertical or Horizontal Mount
Both Available
Both Available
Both Available
Both Available
Vertical Mount
Vertical Mount
Both Available
With Golden Rim
Can be Used as
Front / Rear / Side View Cam
Reversing Camera
Reversing Camera
Front / Rear Camera
Back up Camera with Golden Rim on Fisheye Lens—Eye-catching gloden rim makes the camera unique, 170 degrees wide viewing angle covering most blind spot area. High Definition 1280x720p reversing camera for car is compatible with all monitors which supports RCA video input: double din stereo radio head unit, OEM navigation, Android DVD player, rear view mirror monitor, backup TFT LCD monitor, etc
Built-in Rotating Metal Camera Body—Unlike old-fashioned car cameras which can only adjust the viewing angle by adding gaskets, you can rotate GreenYi pickup rear camera’s lens part to find a best viewing angle with the help of the mini wrench, never need to worry about too high or too low image shown on the monitor. Mini design, solid shinning metal housing, shockproof, longer service life
Rearview Camera with Three Switcher Cables—Cut white cable to switch mirror image(rear view) to non-mirror image(front view). Cut orange cable to switch CVBS video signal to AHD video signal, if your monitor supports AHD 720P 30HZ(NTSC) video settings, you can try it. Cut green cable to turn off the guide line. Please reconnect power supply after cutting any cable, you can also connect it back after cutting the cable if needed
Versatile Vehicle Front / Rear / Side View Camera—You can install the rv blind spot camera at any position you want with vertical(upside down) or horizontal mounting as the camera body is 360-degree-rotatable and there is an extra silicone shell for you if you don’t want to drill a big hole: front bumper/grille, rear deck lid/rear top/trunk handle/fender/5th wheel/tailgate, below the side mirror or on the car body, etc
4Pin Backup Camera—Please note that all of our 4pin backup cameras can’t be connected directly with any other monitors(no matter DVR or dashcam or whatever) which is not compatible with RCA video input AS the pin definition is different
