Price: $239.99
(as of Sep 05, 2024 13:00:20 UTC – Details)
ZEROXCLUB HD Backup Camera System Kit, Loop Recording 7″ Monitor with Wired Rear View Camera BY701A + Rear View Camera
🍀Upgrade Wired Backup Camera System: This model BY701A is a wired system, which was designed for the bus, semi-truck, trailer, RV, van specially. It comes with all the accessaries for easy installation. With the metel “U” shaped bracket, you could mount the monitor on the dashboard, or mount it to windshield with the suction cup. The Camera comes with a low-profile bracket and a set of larger brackets for more flexible mounting. Voltage ranging: 12 to 24V DC power
🍀Loop Recording & Safe Driving: ZEROXCLUB wired backup camera is a good safety option for reversing, because the wide view — 170°angle can help to see the area behind your car easily. If there have children / obstacles / others behind your car, you can see them with the help of the backing camera. Loop video recording function allows it to record what is displayed on the monitor and overwrites the oldest footage with the newest automatically. (a 32GB SD card comes with the package)
🍀Split Screen and Parking Guidelines: The monitor can show the full view for a camera, or dual split screen view, just press CH- button on the monitor to switch views. Note: The second camera needs to purchase separately, please search ASIN: B0BG7Y2DD2 or B0BG7Z3Z47. With the parking guidelines, it can help you to judge the distance between your car and the object around it, which can make your parking safer and easier. Monitor dimension: 7.1 inch(L)*4.5 inch(H)
