HD 1080P Wireless Rear View Camera for BW101/BW102/BW103/BW104, Replacement Backup Camera for ZEROXCLUB System (AHD* ver.)
Price: $89.99
(as of Sep 18, 2024 11:45:20 UTC – Details)
CM-SW01CM-SW01
Note: This wireless camera is not a battery camera. It needs to connect with power.
How to know if the camera is working?
Cover the camera’s light sensor with your hands. If it light up the infrared light, it means that the camera is powered on.
If not, it means that the camera has not been powered on. check the wiring or use another power source or power cord to test.
Why can’t I get this camera to pair?
1. The camera is not compatible with the system. Please get in touch with us to confirm the compatibility of the camera before purchase
2. Do not plug the camera into the power until the pairing count-down had already started
What systems is the camera suitable for?
This camera is suitable for ZEROXCLUB BW101SL/BW102SL/BW103SL/BW104SL and AHD versions of HW02/SW01/SW02/B3C/B4C/B701/BW702/B904.
What about problems with the pairing process?
Please get in touch with us in time.
Connect the Camera
Connect the camera to the power wire. Locate your car’s reverse light wires and you can connect the power wire to the car’s reversing light wire. The black one is ground and the red one is the 12 volt positive wire. Make sure your connections are solid and properly aligned.
CM-SW01CM-SW01
Suitable for the system ZEROXCLUB BW101SL/BW102SL/BW103SL/BW104SL and AHD versions of HW02/SW01/SW02/B3C/B4C/B701/BW702/B904. Model CM-SW01 Waterproof rating IP69k Dimensions 2 19/20″ wide * 2″ tall * 1 13/20″ thick inches Antenna Size 6 inches Night Vision IR Night Vision Power Supply DC 12V ~24V Frequency Band 2.4G Power cord length 9.8ft Connector DC Connector
ZEROXCLUB Single camera
3.8 out of 5 stars
36
4.8 out of 5 stars
12
5.0 out of 5 stars
1
$89.99$89.99
$89.99$89.99
$69.99$69.99
$79.99$79.99
$79.99$79.99
Wireless or Wired
Wireless
Wireless
Wireless
Wired
Wired
BW101/BW102/BW103/BW104…
2023 Version W01/WX02
BY701A/BY104A/BY904A/BY702A…
Waterproof
IR Night Vision
Connector
DC
DC
DC
4-pin
4-pin
【Applicable】Wireless rear view camera is compatible for ZEROXCLUB BW101SL/BW102SL/BW103SL/BW104SL backup camera system. For HW02/SW01/SW02/B3C/B701/BW702 system owned customers, if your camera and monitor have the AHD* label, then this camera is compatible with your system. If you are unable to confirm compatibility, please reach us.
【Signal distance】3rd generation signal technology, 120 feet without delay
【Waterproof】IP69 waterproof, Ambient temperature between -20 degrees and 65 degrees
【Package Contents】a camera, a 10ft cable, two bracket and a few screw
