HD 1080P Vehicle Backup Camera with DVR Monitor System,2 x 8 LED IR Night Vision Reverse Rear View Camera + 9″ IPS AHD 2CH Split Screen with SD Record 12V~24V for RV Truck Trailer Bus 5th Camper
Price: $129.99
(as of Sep 01, 2024 22:30:27 UTC – Details)
This is new update Model AHD 1080P backup camera system for rv trucks and 9 inch DVR recorder reverse rear view ips monitor
The 9 inch large Monitor has two video input and 2-split functions
Easy and Simple to install, Only need to connect the monitor wire with vehicle electronics system:
Red wire to car key on +
Yellow wire to car battery+
Black wire to GND,
Green wire to reversing Trigger+ (or No need to connect)
Applicable to variety of Vehicles: Car,BUS,Truck,RV,Motorhome,camper 5th Pickup Boat Tractor Trailer Heavy Duty etc
Support reversing used or permanently used
9 inch IPS AHD Screen Monitor with DVR Recorder
2x HD 1080P Car Backup Camera DVR Monitor Kit : 9 inch Large Screen + 8 LED IR Night Vision Reverse Camera. Hard wired version Rear View Camera system,No interference and clear image Avoid Blind spot,guarantees safe ,
9 inch DVR monitor With IPS Technology,come with 32GB Memory for video Recording,full color display ,and low power consumption, 2 channels Split Screen Display,It can display two image or single large image,Grid Line Can be turn on/off,Image Support mirror or Flip upside Down
IP69 Waterproof AHD 1080P 2.0 Megapixel Rear Camera with 4 Pin Connector, 8 LED IR Night Vison view clearly at night, 100% Not Wash Out AHD 1080P Sensor HD Rear View Camera, and 2.1mm lens (170° horizontal wide view angle)
The Backup Camera System come with dual Back up camera,and 5m/16ft + 15m/49ft 4-Pin Extension cable Best for 12V/24V Long Bus Truck Trailer RV Van Motorhome Schoolbus Camper Lorry 5th wheel and All other heavy Duty
