HD 1080P RV Backup Camera 9 inch DVR Monitor System,2 x 4 Pin Car Reverse Rear View Mirror Blindspot Camera + 9″ IPS 2 Split Screen with 10m/20m Cable for Semi Truck Trailer Camper
Price: $139.99
(as of Aug 25, 2024 23:15:11 UTC – Details)
Only need to connect the monitor power wire with car electronics system:
Red wire for Car key on ACC+,
Yellow wire to Battery+,
Black wire to GND,
Green wire to reversing Trigger+
Easy to install & easy to play
9″ IPS DVR Recorder Monitor
Display Size: 9 Inch Large Screen
Power requirement:DC 12V-24V
Consumption:8W
Video:2 CH Split Screen
Our Split monitor can display two video at same time,
Also can switch with large full video
Build in SD DVR Loop Recording functions,
Come with 32GB SD Memory Card,Max support 128GB
Reversing Grid Lines Can be turn on or off
Image Can be set with Mirror or None Mirror(front View or Rear View)
Image Can Be Flip Upside Down also
Net Weight: Approx. 1000g
Lauguage:English,Chinese
AHD 18 LED IR Car Rear View Mirror Camera
100% Not Wash Out AHD 1080P Sensor Mirror image
TV system:PAL/NTSC
Lens:2.5mm(150 View angle )
Number of pixels: 2 Megapixel Camera(1920*1080)
Minimum illumination:0 LUX
Backlight compensation:Auto
White Balance:Auto Tracing
Auto Gain Control:Automatic
Night vision:18 LED IR
Video Output:4Pin Connector
work Temperature:-20°C~+60°C
Power Requirement: DC 12V
Weight: Approx 290g
Waterproof:IP 68
Dual RV Back up Camera 9 inch DVR Monitor System 12V/24V:9″ Large Monitor With HD 1080P Reversing Camera Hard wired version Rear View Camera system, come with 32GB Memory for Record,Guarantees safe and clear image Avoid Blind spot
9 inch IPS LCD Monitor Build-in DVR record,2CH Split Screen,It can display two video or single large video,Grid Line Can be turn on/off,Image Support mirror/None Mirror or Flip upside Down
IP68 Waterproof AHD 2.0 Megapixel Front Rear blindspot Back Up camera with 4 Pin Shockproof Connector ,18 LED IR Night Vison view clearly at night, 100% Not Wash Out AHD 1080P Sensor HD Rear View Camera, and 2.5mm lens (150°wide view angle)
The HD 1080p backup camera System come with dual 4Pin security camera,and 10m/33ft + 20m/65ft 4-Pin Extension cable Best for Long Bus Truck Trailer RV Van Motorhome Schoolbus Camper Lorry 5th wheel and All other heavy Duty
