HD 1080P Backup Camera System Kit,9” IPS Monitor with Record Function Infrared Night Vision DVR Monitor +4 Split Screen Waterproof Reverse/Side View Camera for RV Truck/Semi Box Truck/Trailer(12-24V)
Price: $199.99
(as of Aug 02, 2024 22:30:20 UTC – Details)
11
9 Inch Quad Split Screen Wired Backup Camera And Monitor System, + 2 Rear View Cameras + 2 Front View Cameras
1080P Camera FeaturesEffective pixels: 1920*1080 (1080P)Working voltage: 12VWorking current: 110MAFormat: PAL/NTSC optionalMinimum Illumination: 0 LUXLED light range: 5-10 metersWorking temperature: minus 20 degrees -60 degreesWaterproof grade: IP66Lens horizontal angle: 105 degreesNight Vision: Black and White
22
4 Split Screen Modes Choose:
Monitor allow to set display 1/2/3/4 channels at same time CH1-CH4 display image from V1-V4 connector accordingly Automatically Switch: After proper wiring, the monitor will automatically switch to single channel of rear view camera image when the reverse gear is pulled (Operated by remote) Image can be rotated horizontally and vertically for mirror or normal viewing More setting on remote control “Menu”: select settings of Brightness, rotate image, contrast, language etc. Warmly tips: if you want to adjust something, please choose the Channels you need to adjust.
33
44
55
Guide Lines On/Off
4 Cameras are included. Two cameras without parking reference lines + Two cameras with parking reference lines.
Easy to install
The camera can be extended up to 65.6 feet, which can fit most vehicles
IP66 Waterproof Backup Cameras
IP66 and with wide view angle, providing much larger visible area, no more blind spots, make you reverse more safe, and you no longer worry about the bad weather, such as downpour.
66
77
77
HD Glass Lens
The camera is equipped with highly transparent, waterproof and anti-scratch HD glass, providing a clearer and more textured image.
Recording and Playback
Support 4 cameras to record live at the same time, and also support to view playback, so that all details have nowhere to hide.
HD IR Night Vision
Built-in18 IR LED lights, good performance in day and night.See clearly even in poor lighting conditions.
88
The 9-inch IPS high-definition large screen can see more pictures and details, making you pay attention to every placeThe set is equipped with 4 1080P high-definition cameras, allowing you to have more perspectives to observe the surrounding of the vehicle.Support 4 cameras to record live at the same time, and also support to view playback, so that all details have nowhere to hide.If your wiring is correct, the screen will actively display the corresponding picture when you turn left, right or reverse.The camera can be extended up to 65.6 feet, which can fit most vehiclesAt the same time, it supports 4 split screen settings, which allows you to see up to 4 screens of content on the same screenThe set also includes a remote control, which is more convenient for the driver to operate, greatly improves efficiency and avoids accidental touches.
99
【Multi function display】The 9-inch high-definition wireless display is combined with the camera to make the installation easier.1080P HD Monitor & Split Screen 4 Channel and switch video recording function. Support loop recording function, you can set the interval to 1 minute or 3 minutes as the video length.Freely switch the reversing auxiliary line.
【360° View】With 4 cameras as front/rear/side camera, this rv backup camera system can not only provide rear view when you are parking or reversing but also provide 360° view when you are driving.
【DVR Record Funtion】With built-in DVR recording function,This 9 inch monitor Support 4 cameras to record live at the same time, and also support to view playback, so that all details have nowhere to hide.
【IP66 Waterproof and Super IR Night Vision】Using full-sealed and glue-filling tech, those side view/front view/rear view camera can work great on all weathers. With infrared LED lights, those backup cameras can provide you bright & clean view at night.
【Easy to Install】This backup camera system powered by fuse box, connected the red to ACC(12-24V), the black connect the Metal (Ground), the green connect the reverse gear circuit as a trigger power, monitor and backup camera will automatically turn ON/OFF when the vehicle is ON/OFF, different channels can set by the button on monitor.If your wiring is correct, the screen will actively display the corresponding picture when you turn left, right or reverse.
【Customer Service】All product will be offered a 30 days’ free refund.12 months factory warranty and brand new replacement post within 24 hours If any defective item when receive .We provide Lifetime Support and 24 Hours Customer Service and Technical Support.
