Haloview MC7108 Wireless RV Backup Camera System 7” Monitor Built in DVR Rear View Camera with Infrared Night Vision and Wide Viewing Angle for Truck/Trailer/RV/Pickups/Camping Car/Van/Farm
Price: $439.98 - $249.99
(as of Sep 10, 2024 13:45:15 UTC – Details)
HALOVIEWHALOVIEW
Haloview MC7108 make a significant improvement in comparison with the MC7101, it has far better image resolution, stronger lens and longer transmission distance, which will bring you a whole new driving experience. The camera captures crystal clear images with 1280×720 resolution, it also features a wide viewing angle of 120 degree, which eliminates all the blind spots, a feature that comes in handy when backing up in dim areas. It is pretty easy to install, and the kit comes with all the necessary cables and accessories needed and a guiding instruction manual. Instructions are simple and easy to follow whether or not you’ve done a similar installation in the past and the process can take less than one hour.
haloviewhaloview
MC7108
HD Digital WirelessWireless Line of Sight Range Up to 984 feetHigh Resolution:1024*600IPS Panel , You can see the image at any angle
haloview MC7108haloview MC7108
MC7108
Video recordingIR LEDs enable night vision up to 32ftIP69K WaterproofSmart IR-CUT filter
HD 720PHD 720P
300m300m
Video recordingVideo recording
120 degrees120 degrees
High Resolution
720P, high definition image quality improve your viewing experience
Long Range Signal Transmission
A long monitor antenna allows better reception for long range signal ,wireless signal range up to 984 feet.
Recording
Monitor support 4-channel composite and single-channel recording in AVI signal format.
120 degree
A wide viewing angle of 120 degree
IPSIPS
Backup Camera Bracket AdapterBackup Camera Bracket Adapter
IPS Panel
IPS Panel , You can see the image at any angle.
SMART IR-CUT
This camera system built-in SMART IR-CUT filter makes image more realistic. If you use 650nm filter at daytime, it will automatically switch to 850nm at night. It makes color more realistic and avoid color blur.
Haloview backup camera bracket adapter compatible with pre-wired RVs.
Please find the bracket adapter by searching this ASIN : B07LGLJWG2
What’s in the Box
7″ Monitor x1Wireless Backup Camera x1U-Support Bracket x1Sun Shied x1Angle Adjustment Screw x4Center Mount Bracket x1BMW Connector Adapter x1Cigarette Lighter x1Camera Conversion Cable x1
1,265
4.2 out of 5 stars
227
3.8 out of 5 stars
100
4.3 out of 5 stars
349
4.0 out of 5 stars
55
$249.99$249.99 $239.99$239.99
— $339.99$339.99 $299.99$299.99
Resolution
HD 720P HD 720P 800X480 HD 720P HD 720P
Compatible camera
CA108/CA109/CA110/CA112 CA108/CA109/CA110/CA112 CA101 CA108/CA109/CA110/CA112 CA108/CA109/CA110/CA112
Wireless system
Transmission distance(line of sight)
984ft 984ft 400ft 1200ft 984ft
Screen size
7” 5” 7” 7” 5”
DVR
IPS
Total Vehicle Length
30-38ft 30-38ft 20-30ft 38-80ft 30-38ft/hitch camera
7″ LCD digital monitor, Built-in recorder. Real time recording, video playback
10-32V wide voltage input, Support 4 wireless camera input,120° wide viewing angle, Wireless Line of Sight Range Up to 984 feet (This kit include 1 monitor+ 1 camera)
Split mode, auto-scan mode and single-display mode available, Normal, mirror, FLIP, MIRROR-FLIP viewing options available
HD 720P Digital Wireless Backup camera system, it has far better image resolution, stronger lens and longer transmission distance, which will bring you a whole new driving experience
The camera’s waterproof level is IP69K rating (highest IP rating) and the vibration rating is 5.9G, Built-in SMART IR-CUT filter image color and more realistic.
