Price: $89.99
(as of Aug 08, 2024 10:00:16 UTC – Details)
9 Inch GPS Navigation for Car Truck with US/MX/CA 2023 Maps
– Equipped with 9 inch touch screen and 2500mAh battery, fast speed and response time to work
– Search for locations by entering addresses, coordinates or POIs(points of interest, e.g. parking lots ), also supports saving favorites and additional stops
– 2023 map materials of 101 regions for the United States, Canada, Mexico and navigation software pre-installed in car GPS
– Support 2D and 3D map display, lifetime free map updates and lane assistant
– Remaining distance, estimated time of arrival and current speed are displayed on the map
– Fast, green, economical and easy route planning in the truck GPS is available for you
– Warnings at points and signs such as curves, speeding are reported via voice broadcast in 33 languages
– Loud voice guidance is possible by connecting the FM function of the navigation system with your car radio
– 7 changeable vehicle modes – GPS navigation for car, truck, bus, taxi, emergency, bicycle and pedestrian
USA/Canada/Mexico 2023 Maps & Lifetime Free Updates
2023 Offline Map of 101 Regions for the United States, Canada and Mexico with 2D/3D map view are pre-installed in the GPS navigation for truck. Map update with us is always free of charge and timeless! No subscription required and just save money!
Parameter:
Port Details: Mini USB Charging Port, AV Port, TF Card Port
Cable Type: Mini USB Charging Cable, Car Charger Cable
Firmware Updates: Not Needed
Compatible Device with Model: Universal
9 Inch Large Touchscreen
Thanks to the 9 inch touch screen, everything is easy to recognize and especially suitable for professional truck drivers. With the upgraded 2500mAh battery, you can use the vehicle navigation for longer. Wince OS makes everything easy to use and even seniors can quickly get started.
Speed Camera Warnings
Handheld GPS unit warns of traffic light, speed changes and road intersections. All of this gives you useful guidance during drive.
Warning setting: Main Menu > Navigation > Settings (Tools icon) > Sound and Warnings > Speed warning Setting: Warn When Speeding/Alert Point Warning/Sign Alerts. In order to activate the sound, please select “Audio and Visual”.
Voice Broadcast
Drive alerts are announced by the vehicle GPS unit via real voice broadcast over 44 languages. Through the FM function of the navigation, you can connect the handheld navigation to the car stereo to get a louder voice guidance. But it does‘t mean that you can listen to FM radio through this GPS navigation.
About Charing
If the navigation fails to charge, please follow the following methods to troubleshoot:
1. When you are at home, please use the AC adapter of your cell phone or other electrical appliance to connect the mini USB cable to charge the navigation. When you are in your car, please use the supplied car charging cable to charge the navigation.
2. Check if the charging indicator is correct. The charging indicator light is red during charging. Do not unplug the charge until the indicator light turns green which indicate the battery is fully charged. Please charge the GPS navigator when the battery is low or used up.(The indicator light is also green when not charge even if the battery is not fully charged.)
3. Start by charging the navigation with a mini USB charging cable to see if it works. If it doesn’t run, try replacing it with another mini USB cable. If none of them work, please try charging the navigation with the car charging cable. When all the above methods do not work, please write to us.
Product Dimensions : 8.78 x 0.59 x 5.31 inches; 2.25 Pounds
Batteries : 1 Lithium Ion batteries required. (included)
Date First Available : April 24, 2023
Manufacturer : Jimwey
ASIN : B0C3C14K66
Powerful 9 Inch Touchscreen: 9 inch touchscreen is pleasantly large, giving you a clear view of the road and directions on the GPS navigation for truck. Everything also responds quickly and reliably. Perfect for truck drivers and seniors. The handheld GPS unit is held in place by a suction cup and an adhesive plate. The bracket holds the navigation securely on the windshield or on the dashboard and can be flexibly adjusted. There is no shaking or similar while driving.
Numerous Possibilities: The GPS navigation for car searches for locations based on the entered address, coordinates and points of interest, e.g. parking lots, gas stations. Alternative routes such as Fast/Green/Economical/Easy are available and lane assist is also supported. Arrival time, remaining distance or current speed can be displayed on the truck GPS while driving. Saving of additional Stops and favorites is completely trouble-free. Everything ready for immediate use!
Offline and Lifetime Free Map: Built-in GPS chip enables satellite signal search. 2D/3D map display in kilometers/meters/miles/feet/yards and 2023 maps of major 101 regions for North America already pre-installed in the navigation system, including the United States, Canada, Mexico. No need to network, just navigate offline with the software installed. Map updates are valid for life and can be successfully made through the links that we have written in the manual.
Drive Alerts & Voice Broadcast: Safe driving is the most important thing! Clear and useful voice guidance in over 40 different languages are pre-installed in the GPS navigation device. These remind you of speed camera warnings such as traffic light, speed limit, curve or intersection. With FM transmission, you can also get the sound from vehicle GPS unit to your car by taking the car charger cable and selecting the same FM frequency. Be all ears and find your way right!
The vehicle navigation is compatible with most 12V-24V vehicles such as car, truck, bus, taxi, bicycle, pedestrian and emergency. It comes with 2100mAh battery. Thanks to the built-in video and music player, the car GPS can also be used as an entertainment medium. The package includes car charger cable and USB cable(Mini USB Charging Port and charging by using the USB cable to connect with an AC adaptor of your mobile phone, Cigarette lighter or other electronics).
