GPS Navigation for Car: 7 inch 2.5D Screen Car Semi Truck GPS Navigation System for Commercial Drivers Truckers Voice Guidance, Light Alert, Speed Camera Warning, Free Life Time Map Update
Price: $59.99 - $39.99
(as of Sep 05, 2024 07:15:12 UTC – Details)
GPS navigation for carGPS navigation for car
RONGJI 7 Inches 2.5D HD Screen GPS Navigation for Car Truck,Semi truck,RV
Screen 2.5D HD Curved Edge Screen Operating System Win CE 6.0 with 8GB ROM (expandable) and 256MB RAM Display Resolution 800 x 480 Pixels Picture Support E-album, JPG, GIF, BMP and PNG. Audio Support Windows Media Audio Standard (WMA) (.wma): , MP3 (.mp3) and WAV (.wav). Video Support Supporrt WMV9, MPG4, Divx ang MPEG2( res. 800 x 480), AVI, ASF, WMV etc. Map Update Free for lifetime (From Amazon–Order–Problem with order–other issue–write to us–get answer in 24 hours) Power Supply Integrated rechargeable Lithium-Polymer Battery, USB Charge Vehicle Power Cable: Input 12V /30V Output 5V/2.5A Card Slot SSD / MMC slot. Support SD card up to 32GB. Ports 3.5mm Stereo Headphone Jackfull speed USB Client 2.0(12Mbps), mini USB interface. Speakers and Headphones Speaker: Built in, 1.5W / 8Ohms ; Headphone: Hi-Fi stereo sound 20mW / 32Ohms Menu Language Support Chinese, English, German, Spanish, Portugese, French, Serbian etc
KINDLY REMINDER
To avoid damage due to current surge, plug in the car charger after the automobile is started.To make sure the navigator always on, please keep chargingthe navigator during use it.
truck GPStruck GPS
RONGJI Truck GPS Navigation is pre-installed the maps which contains the United States, Canada and Mexico. The maps for other countries need to be download.
car gpscar gps gps navigationgps navigation gps navigation for truckgps navigation for truck trucker gpstrucker gps
Semi Truck GPS NavigationSemi Truck GPS Navigation
Why I cannot startup my GPS navigation?
Please use the 5V 3A wall charger to charge it before you use it at the first time.
Why Battery can’t be charged?
Please use the 5V 3A wall charger to charge it at home and do not charge it via USB cable through computer or laptop.
Why GPS navgation is cut off suddently?
Low battery or check the condiction of the cable and charger.
Why it showed no signal even at the open area?
The signal is weak, it need more than 3 minutes to receive the signal.
Map date is lost or need update to the newest map?
Map updating steps is sent together with GPS. Also, we provide 7*24 hours after-sales service. (From Amazon–Problem with order–other issue–write to us–get answer in 24 hours)
Package Dimensions ‏ : ‎ 8.43 x 5.59 x 3.7 inches; 1.2 Pounds
Batteries ‏ : ‎ 2 Lithium Ion batteries required. (included)
Date First Available ‏ : ‎ April 23, 2023
Manufacturer ‏ : ‎ Shenzhen Rongji Electronics Co., Ltd
ASIN ‏ : ‎ B0C3B491FH
Country of Origin ‏ : ‎ China
【2.5D Screen Car Navigation】GPS Navigation is equipped with 2.5D curved screen with a wider viewing angle, a more clear screen and better light transmission. Maps will be displayed clearly even in sunlight. Screen corner is surrounded by the plastic cover which can protect the screen from damage
【 Professional Navigation System】RONGJI 7 inch GPS Navigation for Car, Truck, Motor-home and RV. (1)You Can Customize Route According to Your Vehicle’s Weight, Length, Height and Width, Avoid Roads with Width/Height/Weight Restrictions. (2) Intelligent Route Planning Provide you a Fast & Economical way.(3)Support Postcode, Address, Coordinates, Favorite and POI Search, such as gas stations, rest areas, etc. (4) Display Current Speed and ETA
【Free Lifetime Map Updates 】Rongji 7 inch gps navigation for car is pre-installed with the latest 2023 North America maps, including US, Canada, Mexico maps with 2D/3D map display. It comes with a map download manual, You can regularly download latest maps for your GPS navigation
【Intelligent Navigation Routes】Smart GPS Navigation supports multiple navigation modes – truck, car, bus, pedestrian, cab, bicycle, emergency, etc., for your diverse trips and escorts. It is a best gps navigation for you
【Accurate GPS Navigation Signal】The Truck GPS System is based on offline navigation, which must work based on the active GPS signal. The built-in GPS chip works without a network, so you don’t have to connect with phone. Note: If the satellite signal can not be searched, it may be because of the weak signal place. Please search the GPS Navigation signal at a open area and keep for about 3 mins
