GloBosenPur Car-Cup-Holder-Expander for Car Organizer with Adjustable Base,Compatible with Yeti 20/26/30 oz Hydro Flasks Large 32/40oz, Fits Most Cup Holder, Diameter Bottles in 4.11″-4.44″ (1pcs)
Price: $9.99
(as of Aug 22, 2024 14:00:21 UTC – Details)
car cup holdercar cup holder
Why choose our car cup holder?
Our Car Cup Adapter works like a charm, can easily be modified for various sized cup holders, and gives you great peace of mind that you won’t be mopping up spills!Our car cup holder can also work with most popular brands bottles of 18-40 OZ and many large fast food cups in 3″-3.8″ diameter.Our car cup holder with 2U-SHAPED GROOVEDon’t worry about the adjustment of the position of the cup, you can easily pick up the drink beside you whether you sit on the left or rightOur car cups deepen the base depth and add more cup mouth anti-slip pads and deliver a base anti-skid pad, so that you can drive happily and safely without worrying about your cup being thrown out due to emergency braking, and it will not come with the cup holder. pull out
Our car cup holder extender works great with most popular brands of water-bottles, including, but not limited to:
The Silicone Mat DesignThe Silicone Mat Design
Tab Design & Coaster
The multi-length tabs allow the adapter to work with a wide variety of bottles. Securely holds tapered cups and most 18-40oz. bottles.
The silicone coaster on bottom helps prevent bottles from rattling or sliding while driving.
Extra Thick Pads
The extra thick pads on the ends of the expanding legs are soft enough to form to the shape/angle of the walls of the existing cup holder, yet firm enough to provide stability.
This holds the adapter securely in place, even off-road.
2U-Shaped Groove
No need to reassemble
Proprietary Tab Material
Makes it effortless to insert or remove bottles from the adapter without pulling the adapter out of the car’s cup holder.
Other materials may grip the sides of bottle, making it difficult to safely add or remove a bottle from the adapter.
2U-SHAPED GROOVE-You can easily pick up the drink in our cup holder expander whether you sit on the left or right,no need to replace the cup holder seat.It is easy to remover the cup holder from the slot. And the cup holder has a base deep enough to provide great balance for your water bottle.
EASY TO INSTALL: Both the base and cup holder are made of high-quality ABS, which is sturdy, durable and easy to install. The extendable base allows the adapter to stay firmly in place. Just rotate cup holder until prongs extend and tighten against your car’s center console cup holder.
FIT MOST 32 OUNCE – 40 OUNCE WIDE BOTTLES & MUGS IN 3.4″-4″: Car cup holder expander is big enough for oversized thermoses, it also can work with most popular brands bottles and mugs in 3.4″-4″ diameter.
EXTENDABLE BASE: Insert is expandable from 2.6″-3.8″ in diameter to fit many different automotive cupholders. Just twist the top of the adapter to expand or retract the base. It also works great for golf-carts, motorcycles, boats, trucks, and RV’s. Our extra thick pads on the expanding base ensure the adapter stays securely in your cup holder.
24 hours sever: The adapter is designed to handle even the most rugged driving conditions. If you have any problem please message us by email.we will reply in 24 hours
