GENSROCK Portable Power Station, 88Wh Outdoor Solar Generator, Lithium Battery Power Bank with 110V/150W Peak AC Outlet,QC 3.0, Type-C, LED Flashlight for CPAP Home Camping Travel Emergency.
Price: $89.98
(as of Aug 13, 2024 13:30:12 UTC – Details)
Portable Power StationPortable Power Station
Outdoor GeneratorsOutdoor Generators
Lithium BatteryLithium Battery
PRODUCT SPECIFICATIONS
Built-In Battery 88Wh (24,000mAh, 3.7V) Adapter Input DC 15V⎓1.5A Solar Panel Input DC 15V-24V⎓1.5A Max 2*DC Output 12V⎓10A Max 2*USB A QC3.0 Output 5V⎓3A, 9V⎓2A, 12V⎓1.5A (18W Max) 1*USB A Output 5V⎓2.4A 1*USB C Output 5V⎓3A, 9V⎓2A, 12V⎓1.5A (18W Max) 2*AC Output 110V/60Hz (2 prongs & 3 prongs) , 120W (Peak 150W) Bulb Type Adjustable LED Flashlight 1-3W Product Size (L*W*H) 6.6 * 4 * 3 inches Product Weight 2.3 lbs
easy to carry 12V DC Output Multiple System Protection Portable Power 1 Easy To Carry 2 2*12V DC Output 3 BMS Protection Systerm 4 Package Contents
Solar GeneratorSolar Generator
This portable power station just press the LED button to switch freely between constant light and SOS mode.
In the highest brightness level, it will run for about 30 hrs on full charge. In the lowest brightness level which is 60 lumens, it will run for about 90hrs on full charge.
CPAP BatteryCPAP Battery
[Portable Power]: Super slim size (6.6 x 4 x 3 inches) and light weight (2.3 lbs). Portable power station with movable handle design is not only for emergency power at home, but also for camping or wherever you need power when on the go. Perfect for charge phone, laptop, iPad, camera, wireless headphones, etc.
[Multi Output]: The portable power station equipped with 88Wh (24000mAh, 3.7V) capacity, 2*QC 3.0 USB ports , 1*USB ports (5V 2.4A), 1*USB C port(18W). 2*DC port(12V/10A), 1*2 pole and 1* 3 pole output socket (120W running, 150W peak). Powers cell phone, iPad, tablet, camera, radio, USB powered night light, mini fan under 150W. You can use the light (5W) for about 15 hours or more, use the smartphone for about 5 times or more, and use the PSP for more than 10 hours.
[LED Lights]: This portable generator is built with a LED flashlight, which could emit 2 lighting modes (3 Levels brightness steady light mode , SOS mode) to meet your different needs. Press the LED flashlight switch to change the mode. When you go out camping or experience power outages, this power supply can always help you out.
[Three Recharging Modes]: 88Wh portable rechargeable power station with Three methods to charge the portable power station. 1. You can fully charge the power supply via AC outlet (adapter included) 2. It can be charged under the sun with a solar panel(15V-24V)(Solar Panel Not Included). 3. The power station can be charged by socket of the car and car charger efficiently. Cycle life >1000 times.
[24-Month Product Guarantee]: The GENSROCK portable power station comes with a 24-month product guarantee, and GENSROCK offers a 24×7 specialist customer service. In the box: 1*88Wh Portable Power Station, 1*AC Power Adapter, 1*Car Charger, 1*User Manual.
[Tips]: If you have any questions during use or need operation instructions, please contact us.
