Price: $599.99 - $489.99
(as of Aug 27, 2024 05:45:12 UTC – Details)
RV Ready
An easily accessible TT-30R RV outlet makes the GM3200i perfect for travel trailers . The GM3200i is strong enough to power everything in most RVs .
At just 47.3 pounds , the GM3200i is one of the lightest 3000w inverters in the industry . The sturdy handle facilitates long-distance carrying .Slightly smaller than a car refrigerator , it can easily fit in the trunk of a minivan , It is the best choice for camping
About GENMAX
GENMAX is a research, production and sales technology company with more than a decade of experience designing and manufacturing reliable and durable power supplies for the North American and world markets, and genMAX generators are your best choice for home, work, entertainment, or preparing for natural disasters,GENMAX products are the standard of performance excellence.
GENMAX 3200-Watt RV Ready Portable Generator ( EPA )
The best GENMAX inverter generators power you up when your home is without power or when you’re traveling . Is your ideal portable power solution .
Engine:4-stroke 145cc OHVFuel Tank:1 Gallon Fuel Type:GasolineStarting Wattage:3200WRunning Wattage:2800WProduct Dimensions:18.9″ x 17.3″ x11.5″Runtime:4 Hours 50%-LoadLow Oil Shut-offEmissions:EPA
AC Pure Sine Wave
Total harmonic distortion is less than 3% compared to real sine waves,and can be handled by even the most sensitive electronic devices
Parallel Ready
Parallel ports allow you to pair the GM3200I with a compatible GENMAX inverter generator,using a combination of parallel power cords ( sold separately ) to increase power , plug-and-play .
Lightweight Design
Weighing just 47.3 pounds,the GM3200i inverter is one of the lightest 3000-watt inverters in the industry,with the best power-to-weight ratio.Maximum
portability with a convenient carry handle
Economy Mode
Maximize fuel economy by using Eco mode , allowing the generator’s motor to automatically adjust fuel consumption to extend running time and engine life
【Strong Power】GM3200i uses newest high speed 5.2 HP 145cc gas engine, output 3200 surging watts and 2800 running watts , this powerful inverter generator is the dream ideal product for emergency home backup power, jobsite use, tailgate or camping with your RV.
【Super Quiet, Fuel Saving】Fully enclosed design dramatically reduces noise levels. At 23 feet distance, 57 DBA with no-load, 62 DBA with 25% load, 68DBA with full load. inverter technology provides clean, stable power for sensitive electronics, tools and appliances,Capable of running for a long time for 8 hours in the case of 1 gallon of fuel, with “economy mode” for maximum fuel efficiency.
【Ultra-Lightweight, Extensive Use】At only 47.3 pounds, this inverter is one of the lightest 3000-watt inverters in the industry and has the best power-to-weight ratio. It can operate a wide variety of appliances,Compact and lightweight makes transportation easy with built-in handle.
【Strong Panel With Parallel Function】 LED indicators alert you when unit is low on oil, overloaded or ready-to-use. USB ports to charge mobile devices. 120v 20A duplex and 120v 30A Covered outlets provide added protection from the environment. Parallel ready to connect two GM3200i inverter generator for twice the power. (parallel kit sold separately).
【GENMAX Support】Includes 1-year warranty with FREE lifetime technical support from experts.
