GENMAX Portable Generator,1200W Ultra-Quiet Gas Engine, EPA Compliant, Eco-Mode Feature, Ultra Lightweight for Backup Home Use & Camping (GM1200i)
Price: $349.99 - $299.00
(as of Aug 14, 2024 18:15:11 UTC – Details)
GENMAXGENMAX
GENMAXGENMAX
GENMAXGENMAX
GENMAXGENMAX About GENMAX
GENMAX is a research, production and sales technology company with more than a decade of experience designing and manufacturing reliable and durable power supplies for the North American and world markets, and genMAX generators are your best choice for home, work, entertainment, or preparing for natural disasters,GENMAX products are the standard of performance excellence
Our 57cc 4-stroke OHV engine operates at an extremely quiet 58db at quarter load;Sound equivalent to normal conversation,Provide safe power wherever needed
Safe For Electronics. Produces clean,reliable power and limits total harmonic distortion to under 1.2%,making it safe enough to run laptops,cellphones,tablets,and other.vulnerable electronics.
Engine: 4-stroke 57cc OHVFuel Tank : 0.7 GallonStarting Wattage:1200WRunning Wattage:1000WProduct Dimensions:16.5″x9.4″x15.7″Runtime:6.5Hours Half Load Run Time
Covered OutletsCovered Outlets
PARALLEL READYPARALLEL READY
Lightweight DesignLightweight Design
USB CHARGINGUSB CHARGING
Covered Outlets
Including two covered 120V 20A household outlets (5-20R)
PARALLEL READY
The optional parallel kit enables this inverter to connect with another 2000-watt GENMAX inverter to double your output power.
Lightweight Design
The 25-pound body and compact form make it easy to move the generator from the car to your campsite.
USB CHARGING
Handy dual 1A/2.1A ports USB adapter you can use to power your phone,laptop , tablet,or similar device.
CONTROL PANELCONTROL PANEL
GENMAXGENMAX
【Powerful Engine And Safe For Sensitive Electronics 】The GENMAX 1200 Starting Watts Inverter Generator is powered by a 57cc 4- stroke OHV gas engine,with inverter technology produce 1200 Starting Watts/ 1000 Running Watts clean power (less than 3% THD), confidently connect your sensitive electronics such as TV, lights, fans, small power tools and more on camping trips, etc.
【Ultralight And Small Size】At only 25.3pounds, GM1200i is one of the lightest 1000w inverter in this industry. The sturdy handle makes it easy to carry for long distance.
【Extremely Quiet,Fuel Efficient】 As Low as 58 dBA Noise Output with 25% loading at 23 feets, and up to 6.5 Hours of Run Time with 50% loading on a 0.66 Gallon Gas Tank – Features “Economy Mode” for Maximum Fuel Efficiency.
【Power Panel】Includes low oil alarm, overload alarm,Co warning light and output indicator features “Eco mode” for conserving energy and maximum fuel efficiency ,120V/20A outlets and one5V / 1A outlets , one 5V / 2.1A outlets ,parallel ready.
【CO Detect Shutdown】 Includes CO Detect shutdown sensor for Prevention of Carbon Monoxide Poisoning.
