Garmin tactix 7 Pro Ballistics Edition Rugged Tactical GPS Touchscreen Smartwatch, Black/Nylon Band | Solar Power, Military Standard, Up to 28 Day Battery Life with Signature Series Power Bundle
Price: $1,609.99
(as of Aug 14, 2024 10:15:10 UTC – Details)
bannerbanner
11
22
33
44
BUILT-IN GREEN OR WHITE FLASHLIGHT
To help guide your way in low-light conditions, a built-in multi-LED flashlight provides quick access to a bright, steady beam in either green or white light.
STEALTH MODE
While keeping the watch operational, stealth mode stops storing and sharing your GPS position and disables wireless connectivity and communication. Easily switch between daytime view and nighttime view with a screen that can be read by night vision goggles.
DIRECT-TO NAVIGATION
Navigate straight to a location or waypoint in the worldwide aeronautical database. Or choose the Nearest function to activate a path to a nearby airport.
APPLIED BALLISTICS ELITE SOFTWARE
Calculate aiming solutions for long-range shooting in the field with a built-in ballistics calculator.
55
1313
77
88
BUILT-IN SPORTS APPS
Use preloaded activity profiles for trail running, swimming, running, biking, hiking, rowing, skiing, golfing, surfing, indoor climbing, HIIT workouts, daily workout suggestions and more.
PULSE OX SENSOR
For altitude acclimation or sleep monitoring, a Pulse Ox sensor4 uses light beams at your wrist to gauge how well your body is absorbing oxygen.
SOLAR CHARGED BATTERY
Get up to 37 days of battery life in smartwatch mode with solar charging enabled1 — and up to 122 hours in GPS mode with solar charging enabled2.
PERFORMANCE METRICS
View advanced training metrics that include running dynamics, heat and altitude-adjusted VO2 max, trail run VO2 max, recovery advisor and more. Use this data to track and manage your exertion, and help avoid overexerting at the start of your run or bike.
99
1010
1111
1212
MULTI-BAND GNSS SUPPORT
Access multiple global navigation satellite systems (GPS, GLONASS, Galileo). Get access to multiple frequencies sent by navigation satellites for improved position accuracy in areas where GNSS signals are reflected, weak or typically don’t penetrate.
ABC SENSORS
Navigate your next trail with ABC sensors, including an altimeter for elevation data, barometer to monitor weather and 3-axis electronic compass.
GOLF COURSE MAPS
Access full-color CourseView maps for more than 42,000 golf courses around the world, and get button targeting and the PlaysLike Distance feature.
WRIST-BASED HEART RATE
Optical heart rate technology gauges activity intensity as well as heart rate variability to calculate your stress level. It also tracks underwater without a heart rate strap.
1313
1414
1515
1616
CONNECT IQ STORE
Download custom watch faces, add data fields, and get apps and widgets from the Connect IQ Store when paired with your compatible device.
SMART NOTIFICATIONS
Receive emails, texts and alerts right on your watch when paired with a compatible device.
MUSIC APPS
Store up to 2,000 songs, or access streaming apps from your compatible services, including Spotify, Deezer and Amazon Music, and listen through headphones with BLUETOOTH technology.
GARMIN PAY CONTACTLESS PAYMENTS
Breeze through checkout lines with Garmin Pay contactless payment solution through participating providers.
4.5 out of 5 stars
23
4.5 out of 5 stars
23
4.5 out of 5 stars
23
$1,104.99$1,104.99 $1,304.99$1,304.99 $1,604.99$1,604.99
Display Size
1.4″ 1.4″ 1.4″
Touchscreen
Solar Charging
Ballistics
Band Material
Silicone Band Nylon Band Nylon Band
Connectivity
BLUETOOTH, ANT+, Wi-Fi BLUETOOTH, ANT+, Wi-Fi BLUETOOTH, ANT+, Wi-Fi
Navigation
Multi-GNSS Satellite Systems (GPS, GLONASS & Galileo) Multi-GNSS Satellite Systems (GPS, GLONASS & Galileo) Multi-GNSS Satellite Systems (GPS, GLONASS & Galileo)
Fenix 7 ChargerFenix 7 Charger
SIGNATURE SERIES CHARGING STAND
Our high quality aluminum alloy watch charger stand with charging cable is fast charging with anti-slip mats on the bottom so you can be sure your Garmin Tactix 7 is secure.
Garmin Fenix Watch Stand RotateGarmin Fenix Watch Stand Rotate
ROTATING CHARGING HEAD FOR COMPATIBILITY
The angle of charging port can be rotated and repositioned to have the charging port positioned in one of four orientations, above, below, to the left, or to the right of center to accommodate the different locations of the charging port on different devices.
Charger and WallCharger and Wall
SIGNATURE SERIES CAR AND WALL PLUG WITH POWER BANK
With the 5000mAH Signature Series battery, you can extend the battery life of your Tactix 7. You can also use the Signature Series battery to charge your phone to ensure that you don’t run out of power. Included in the Signature Series Charger Bundle is a Wall Plug and Car Plug to make it easy to charge your devices on the go.
Stand
Rotating
Charging Bundle
Product Dimensions ‏ : ‎ 2.01 x 2.01 x 0.59 inches; 2.68 ounces
Item model number ‏ : ‎ XN-P01
Department ‏ : ‎ mens
Batteries ‏ : ‎ 1 Lithium Ion batteries required. (included)
Date First Available ‏ : ‎ January 9, 2023
Manufacturer ‏ : ‎ Certified Brands
ASIN ‏ : ‎ B0BRYJWJ33
Country of Origin ‏ : ‎ Taiwan
This Bundle Contains: 1 Garmin tactix 7, Pro Ballistics Edition, Ruggedly Built Tactical GPS Watch with Solar Charging Capabilities, Applied Ballistics and Nylon Band + 1 Signature Series Watch Stand with Charging Cable + 1 Signature Series 5000mAh Portable Power Bank with Wall Charger and Car Plug Adapter
Rugged, military-inspired design features an always-on 1.4” solar powered display, black DLC-coated steel bezel, black PVD-coated steel rear cover and new LED flashlight. Sapphire lens with traditional button controls and a touchscreen display to access selections.
Specialized tactical features include Jumpmaster mode, stealth mode, waypoint projection, dual-position format, preloaded tactical activity and a kill switch to erase user data and location. Built-in Applied Ballistics calculator for shooting solutions and compatibility with the AB Synapse Garmin app where you can create custom ballistic profiles
Navigate the outdoors with preloaded TopoActive and ski maps, navigation sensors, and multi-GNSS and multi-band support, providing the highest level of positional accuracy from Garmin. Training and performance features with more than 30 built-in sports apps, endurance and stamina, and performance metrics
When paired with your compatible smartphone, enjoy comprehensive health and wellness monitoring plus all-day functionality with smart notifications, Garmin Pay contactless payments (with a supported country and payment network) and up to 37 days of battery life when solar charging (Assumes all-day wear with 3 hours per day outside in 50,000 lux conditions) in smartwatch mode
