Garmin Foretrex 801, Wrist-Mounted GPS Navigation with Strap, Upgraded Multi-Band GNSS, Longer Battery Life
Price: $247.90
(as of Aug 10, 2024 02:15:22 UTC – Details)
Make the mission possible with the Foretrex® 801 wrist-mounted GPS navigator. Navigate with improved positional accuracy, thanks to the upgraded multi-band signal reception technology. Get up to 100 hours of battery life in GPS mode. Tactical features, such as jumpmaster mode, stealth mode and kill switch, equip you for the mission and beyond. The improved monochromatic screen gives you better visibility in all lighting conditions and is easy to read with night vision goggles. The rugged device is built to military standards and has an IPX7 water rating. Plan and review your adventures with the Garmin Explore™ smartphone app. Get smart notifications and inReach® device messages delivered to Foretrex 801 when connected to your compatible smartphone or your inReach satellite communicator (active subscription required; jurisdiction restrictions may apply).
Wrist-mounted GPS navigator with a monochromatic screen is easy to read in a variety of lighting conditions
Navigate the terrain with advanced sensors, including a 3-axis accelerometer, 3-axis compass and barometric altimeter
Get improved position accuracy with upgraded multi-band signal reception technology
Use stealth mode to stop storing and sharing GPS data and disable wireless connectivity
Hit the kill switch to erase the device memory in case of security issues
Easily read the screen with night vision goggles
Connect to the Garmin Explore app to plan and review your adventures
Pair with your compatible inReach satellite communicator (active subscription required; jurisdiction restrictions may apply), and view messages directly on the screen
Use jumpmaster mode to calculate high-altitude release points in accordance with military guidelines
Get smart notifications when paired with your compatible smartphone
