Price: $729.99
(as of Aug 11, 2024 13:15:13 UTC – Details)
Edge® 1040 Solar is powered by the sun and packed with everything under it. It’s our first GPS bike computer with solar charging and multi-band GNSS technology, so you can ride longer and get even better coverage under dense tree cover or the urban canyon. The Edge 1040 Solar bike computer also has performance features that help you understand your strengths and weaknesses. When paired with your compatible sensors, it can even help you manage your efforts by providing power targets throughout a course and stamina feature insights, so you know how much gas is left in the tank. And the setup is simple, so you can take it out of the box and be out riding in no time.
Advanced GPS bike computer combines superior navigation, planning and performance tracking, cycling awareness and smart connectivity.Control Method:Application.Special Feature:Bluetooth.
The Power Glass solar charging lens extends battery life, giving you up to 100 hours in battery saver mode or up to 45 hours in demanding use cases; during daytime rides, it adds up to 42 minutes per hour in battery saver mode and up to 20 minutes per hour in demanding use cases (assuming continuous 75,000 lux conditions during daytime riding)
Find your way in the most challenging environments with multi-band GNSS technology that provides enhanced positioning accuracy
Simplified setup and a streamlined interface make it quick and easy to access the information, courses and tools you need and even adjust data fields right from the Edge device or from your paired smartphone
Classify your strengths as a cyclist, and compare your cycling ability to the demands of a specific course, when paired with your compatible sensors, so you can focus your training and improvement in the right areas
Manage your efforts with the power guide feature, which recommends power targets throughout a course when paired with your compatible sensors
Get stamina feature insights while you ride, when paired with your compatible sensors, so you can keep an eye on how much longer you can really push it
Stay on top of your training program with prompts to complete missed workouts
Ride like a local, whatever your bike type, with improved ride type-specific maps that highlight popular roads and trails plus searchable points of interest
Connect with your favorite smart-device apps and platforms, including Strava, Komoot, TrainingPeaks and many more (Requires Garmin Connect smart-device app)
