Price: $142.98
(as of Sep 15, 2024 18:00:27 UTC – Details)
GOCOM G9 Two Way Radios, Enjoy Your Adventure – Explorers absolutely love the features of this walkie talkies!
Stay Connected with Your Friend/Family via GOCOM G9 Two Way Radio
GOCOM G9 is perfect for your outdoor excursions as well as life’s everyday adventures. Come with headsets & batteries, perfert for camping trip, hiking trip, hunting, fishing or even to your backyard or nearby park.
Understand the range of walkie-talkies:
The signal of the walkie-talkie is weakened, which may be blocked by obstacles. Obstacles such as trees will affect the range of the walkie-talkie, and obstacles such as mountains may completely block it. Therefore, even if forested areas do weaken the signal, in these areas, you should expect your range to be limited by the hills blocking the signal, not the trees absorbing the signal. In more urban areas, the obstruction of buildings will be more serious. Most concrete, brick or metal structures will reflect radio waves, so if you use a 2W walkie-talkie in a city, you can get a range of less than 1 mile.
22 Channels, each with 121 Privacy Codes
G9 FRS two way radios feature 22 channels, along with channel scan to check for activity. and it supports up to 32 miles communication range in Mountain to valley, provide 14 miles communication in open water and up to 3 miles in neighbourhood.
This G9 Walkie talkies gives you up to 2,662 channel options to help block other conversations.
Walkie Talkies for adults in outdoor activities hiking camping road trip as well as for kids to keep in contact with parents
GOCOM G9 Walkie Talkies Radio – Direct charging, Micro USB Charging Port – 5FT Drop resistance – NOAA Weather Scan + Alert – IP67 Weatherproof – iVOX/VOX Hands-free – PTT Timeout Timer – Dual Power & Hidden Display – 4x Belt Clips
Hands-free function
With iVOX/VOX acting like a speakerphone and allowing hands-free communication, you can keep on moving without stopping to answer a call.
Withstand in extreme weather situation
Built NOAA Weather Alert, keep updated with real-time weather conditions by turning on one of 11 weather channels or initiating weather alerts. Even snow, hurricane & heavy rain but stay in communication.
G9 FRS Radio with rugged design for climbers, skiers, and other outdoor adventurers
SOS emergency lamp
When in danger or unexpected emergencies, easily ask for help. User can use this feature to emit SOS signal. This will allows others to know that you have an impending danger.
Extra bright flashlight
Select the white LED setting on the built-in flashlight to light your way during evening activities or power outages.
FRS two way radio
It is license free radio that provides clear point-to-point communication, with superior reception, transmission, and sound quality.
Ideal for outdoor activities
With a range of up to 32 miles and the freedom to communicate wirelessly, GOCOM G9 lets you stay in touch with family and friends, whether tackling a back country trail or fishing.
Weather alert
Select proper weather radio and pick up current conditions;works great during storm season
Floating design
Never worries about using it in the wildest area or lose your radio, with the G9 ability to float and water-activated flashlight.
Product Dimensions : 8.03 x 1.77 x 2.36 inches; 1.9 Pounds
Item model number : f65692f2-ec9f-4d9c-8381-2fda471f6c85
Batteries : 3 AA batteries required. (included)
Date First Available : November 18, 2020
Manufacturer : GOCOM
ASIN : B08NSYTKPH
Country of Origin : China
Waterproof Walkie Talkies Floating – With the IP67 waterproof & water activated LED design, GOCOM G9 Walkie Talkies for Adults features fully waterproof, submersible and floating, when the talkies drop into the water, the Led will be activated automatically and it will float in the water. Besides, the waterproof radios adopt dewatering system (bottom speaker hole water droplet), ideal for sea activities.
22 Channels – Walkie talkies long range for adults with earpiece 22 channels and 121 privacy codes, it’s easy to find an available channel, to help conversations privacy, you can set the particular channel for your friends and family.
NOAA Weather Alert – Walkie Talkies NOAA Weather Scan will automatically scan through 11 available weather (WX) band channels and locks onto the strongest weather channel to alert you of severe weather updates. NOAA Weather Alert will sound an alarm indicating that there is a risk of severe weather in your area, and you will always be prepared for the unexpected.
SOS Emergency Lamp & LED Flashlight: – Emergency walkie talkies advanced built-in flashlight with white and red LEDs, select the LED setting on the built-in flashlight to light your way during evening activities, unexpected emergencies or power outages. Low battery alert present to remind you when batteries are running low.
Hands free Walkie Talkies – VOX function can free your hands when you are busy, convenient reply to companion.
1200mAh Ni-MH Rechargeable Battery – 3 X 1200mAh AA NiMH battery supports normal work use;LCD screen and big keyboard is perfect for adults and beginners; Dual watch allow you to set up two channels and enable you not miss any call.
What You Can Get – 4 x GOCOM G9 Adult FRS Walkie Talkies, 2 x Desktop Charger, 4 x Belt Clips, 2 x Micro-USB Cable, 4 x Earpiece, 12 x AA NiMH Rechargeable Battery, 1 x User Manual. We offer 24/7 friendly customer service, any problem, please feel free to contact us for help.
