Price: $429.00 - $399.00
(as of Sep 29, 2024 18:00:19 UTC – Details)
DIY Bike to Electric
TONGHSHENG TSDZ2B Dual Clutch Torque Sensor MID Drive Motor & Bottom Bracket 68/73mm
TONGSHENG Motor Packing List
TONGSHENG MID Motor for MTB
TSDZ2B Mid Motor for City BIKE
TSDZ2B Mid Motor for Tricycle
New Version: TSDZ2 Updated to TSDZ2B Which has two clutches designed on the main gear. Main gear is disengaged from the chain during riding, so it feels as easy to ride as a bicycle. It increase the center positioning, which ensures the radial spacing accuracy. It also improves waterproof performance. After changing to a new integrated part, the life of the engine is increased
Power & RPM: TSDZ2B 52V 750W 4000rpm mid mid drive motor kits. Fitting most standard bike with 68/73mm length bottom bracket, only fit for the bike with disc brake and chain drive system, if you need it to fit 100mm or 120mm bottom bracket frame, pls send us the message before ordering
Open Source Firmware: Cyclists or developers can modify the firmware to better suit their specific needs or preferences. This could involve adjusting parameters like power output, throttle response, pedal assist levels, or even integrating additional features
Torque Sensor & Throttle Function: The smart torque sensor can accurately detect the force on your foot and convert it into kinetic energy in time, with excellent starting performance. You can feel the power of starting the e-bike from your feet. It is to be the perfect combination of man and machine. If you get tired, meantime you also can use the throttle
Safe Design: The power output is synchronized with the pedal, as long as the driver releases the pedal, the power will be cut off immediately, and there is no need to install the brake levers. When the crank is idle, the motor does not rotate. It’s as safe as a bicycle
