Price: $259.99
(as of Aug 19, 2024 05:45:22 UTC – Details)
Supports Up to 4 Cameras
The system can support up to four cameras to monitor the road for you, avoid accidents, and make your driving and reversing safer and reliable.
Temperature resistance
Features high/low temperature resistance (-4℉-128℉), Waterproof IP69, works perfectly in any extreme weather.
Night Vision
Built-in Light Sensor and IR lights for safe driving even at night.
Stronger Signal Penetration
With the latest signal technology, you no longer need to worry about speed, distance, obstacles or weather affecting the signal.
🔸Larger 9 inch 1080P Split Screen Monitor:Our 9-inch monitor with 1920×1080 pixels allows you to see more clearly and more details, larger than the common 7-inch screen on the market. The Split Screen monitor can show more than one camera images at the same time, making your driving and reversing more confident and safer. (It supports up to 4 cameras, please ask us for extra camera if you need.)
🔸Advanced Wireless Digital Signal Technology:Apply this technology, the system equipped with superior anti-interference ability, its wireless transmission can reach up to 128FT in open area. The image displays stable, no delay, stays smooth and clear even under car speeds up to 95mph.
🔸Loop Record & Parking Assistance:Features with Loop Recording, monitor can record your driving, and videos may become your evidence when necessary. Parking Lines will make your parking safer and faster. No longer need someone to get off the vehicle to help you see the road or guide you. (It contains a 32GB SD card.)
🔸170 degree Camera with Infrared Lights:IP69 Waterproof cameras with infrared lights make your safety driving in the dark possible, provide you with the best Night Vision. Features high/low temperature resistance (-4℉-198℉), Waterproof IP69, works perfectly in any extreme weather.
👍 Easy to Install & After-sales Service:Voltage range from 12-24V DC Power, accommodates a wide variety of large vehicle as RV/Camper/Truck/5th Wheel Trailer/Bus/Van/Pickup/Farm Mach. If you find defective or something wrong, please tell us, we are Online 24 hours and offer a 24-month replacement support and lifetime after-sales service!
🔸 Please Note : Wireless means that the system transmits the footage captured by the camera to the screen through a wireless signal instead of using a cable. But the cameras and monitor still need to be connected to a power source via power cord to get power to work properly. There is no cable between the cameras and the monitor in a wireless system than in a wired system, so you don’t need to run cables on your vehicle, which is more convenient.
