Fookoo 1080P 10″ Wireless Backup Camera System, 10″ Dual/Quad Split Monitor with Recording, IP69 Waterproof Rear/Front View Cameras, Parking Lines for RV/Truck/Trailer/Van(DW102)
Price: $289.99
(as of Aug 25, 2024 05:46:30 UTC – Details)
101101
Trust in Our Experience!
FOOKOO Has 10 Years Experience in This Field and This Helps Us Understand Your Needs Better.Continual Improvement, Upgraded Firmware and More than One Year Strict Testing, to Ensure Your Driving Safety.
Read Before Purchase
Wireless means the signal from the cameras to the monitor is wireless. There are no cables between the cameras and the monitor.But the cameras and the monitor still need wires to get power and work.
Fookoo 10″ Wireless Backup Camera System Kit
2222
Larger 10-inch Monitor 1920×1080 Pixels allows you to see more clearly and more details. Split screen can show all cameras images at the same time. Monitor Size (CM) : 25 x 16.5 x 4 (Not include bracket)
Easy to Install & Setup Power Supply: DC 12-24V, 1-2A
Without cables between the monitor and the cameras, installation becomes much easier.
Power the monitor via car charger or hardwired.Power the cameras via hardwired.Before install, please test them with a temporary power supply to make sure they aren’t defective and paired. Notice !!!
Wireless means there is no wiring between monitor and cameras, they transfer the images via wireless signal not cables. But they still need to connect to the power source to get power to start working.
What can you get from Fookoo 10″ wireless backup camera system kit?
四个摄像头四个摄像头
xinhaoxinhao
1080P High Definition Images
Digital wireless backup camera designed with infrared lights and newest CCD Sensor and the HD LCD screen offer a super-sharp 1080P maximum resolution, that let you see details such as license plates, street signs more clearly and helps you drive at ease.
Supports Up to 4 Cameras
With the help of multiple cameras, the system will monitor the road conditions for you in all aspects to avoid accidents, making your driving and reversing safer and secured.
*It supports 4 cameras, if you need more cameras, please consult us.
Stable Digital Signal
With the latest signal technology, you no longer have to worry about speed, distance, obstructions or weather affecting the signal. It has superior penetrating power and a signal transmission distance of up to 135 feet, suitable for most RV, trailer, motorhome, truck, camper, etc.
内存内存
分屏分屏
Loop Recording function
Monitoring and recording your driving make driving safer around the clock. It will record what is displayed on the monitor.
When the memory storage is full, the earliest video segments will be overwritten automatically.
The package contains a 32GB SD Card.(Supports 32-128GB SD Card.)
Parking Lines Assistance
Reversing screen with parking line will make your parking safer and faster. No longer need someone to get off the vehicle to help you see what’s going on and guide you.
All you need to do is: use our system and turn on Parking Lines of system.
Dual/Quad Split Screen
Our 10-inch monitor allows you to see more clearly and more details, larger than the common 7-inch or 9-inch screen on the market.
You can choose to view one camera in full screen, or view more than one camera at the same time. It helps eliminate your blind spots, efficiently protecting safety of you and others.
DW102DW102
If you find that an accessory is missing or damaged, please see us for a replacement.
Our cameras can work on Furrion pre-wired RV or trailer with the help of the bracket adapters, so you don’t need to uninstall the pre-wired mount.
The system package doesn’t include the camera bracket adapters, which can be used with Furrion pre-wired RV.If you need the bracket adapter, please reach us with its name, we are willing to provide you.
支架支架
4.3 out of 5 stars
52
4.3 out of 5 stars
52
4.3 out of 5 stars
265
4.3 out of 5 stars
265
4.6 out of 5 stars
50
4.5 out of 5 stars
85
$289.99$289.99 $229.99$229.99 $379.99$379.99 $509.99$509.99 $259.99$259.99 $239.99$239.99
Attribute
Wireless Wireless Wireless Wireless Wireless Wired
Monitor Size
10-inch 10-inch 10-inch 10-inch 10-inch 10-inch
Spilt Screen
Full / Dual / Quad Split Full / Dual / Quad Split Full / Dual / Quad Split Full / Dual / Quad Split Full / Dual / Quad Split Full / Dual Split Screen
Record Function
Parking Lines
Number of Cameras
2 1 3 4 2 2
Maximum Number of Supported Cameras
4 4 4 4 4 2
【Larger 10″ Screen with Clear Images】Our 1080P monitor with 1920*1080 resolution provides you with high-definition images. The 10-inch larger screen will show you more details, making your trip safer and happier. With the assistance of parking lines, parking becomes easily. With the dual/quad split screen, it supports up to 4 cameras, please ask us for extra cameras if you need. The size of the monitor is 9.88*6.46 inch (without bracket).
【Split Screen & Loop Recording】For the dual/quad split screen monitor, you can add more cameras if you need, then you can view images of different cameras simultaneously. The system can record and save what is displayed on the screen. With loop recording, when the SD card is full, the system will automatically overwrite the previous videos. (It contains a 32GB SD card.)
【Advanced Digital Wireless Signal】The system with stable digital signal works flawlessly within 128ft range in open area, enough for any large vehicles. Even at the high speed of 102mph, the monitor will display the surroundings in real time, making your driving more convenient. There is no interference, flicker, blurring or delay.
【IP69 Waterproof Cameras】The IP69 waterproof camera works perfectly in any extreme weather. With 18 infrared lights, the camera can provide HD night vision for you. The lens of the camera can be adjusted up and down, allowing you to view from different angles. The hard metal housing makes the camera serve longer for you.(It can work with Furrion pre-wired RV, please ask us for the bracket adapter.)
【Easy to install & After-Sale Service】Voltage ranging from DC 12-24V power supply is suitable for a wide variety of large vehicles such as RV/Camper/5th Wheel Trailer/Bus/Van/Pickup/Farm Machinery. If you find anything defective or need help, please reach us. We are online 24 hours and we offer a 24-month replacement support and lifetime after-sale service!
【Please Note】Wireless means that the system transmits the footage captured by the camera to the screen through a wireless signal instead of using a cable. But the cameras and monitor still need to be connected to a power source via power cord to get power to work properly. There is no cable between the cameras and the monitor in a wireless system than in a wired system, so you don’t need to run cables on your vehicle, which is more convenient.
