Fookoo Ⅱ HD Wired Backup Camera System Kit,10 inch Dual Split Screen Monitor with Recording IP69 Waterproof Front View Rear View Cameras Parking Lines for Truck/Semi-Trailer/Box Truck/RV(DY102)
Price: $239.99
(as of Jul 30, 2024 18:45:21 UTC – Details)
screenscreen
screenscreen
screen camera accessories Installation
record Split Screen parking line
mirrormirror Image Mirror/Normal
Cameras can be controled separately. You can just flip one camera to get correct image without affecting the image of the other camera. suitablesuitable Wide Compatibility
The system accomodates to various lage vehicles,such as trailer,bus and RV. transfertransfer Signal Stability
Wired systems transmit images through cables, which are more stable and delay-free, no need to worry about signal problems any more! adjustadjust Functional Adjustment
Brightness, contrast, saturation, and other functions can be adjusted through on screen buttons.
scenes scenes scenes scenes
Larger 10 inch Split Screen Monitor:Our 10-inch HD monitor features with Dual Split Screen, allows you see two cameras at the same time and provides more details, larger than the common 7-inch/9-inch screen on the market. It is more suitable for the large vehicles as: 5th Wheel Trailer/Tractor/RV/Truck/Bus/Semi-Trailer/Box Truck, etc.
High-quality Camera with Glass Lenses:IP69 Waterproof camera with CCD sensor provides you the clear and color images. Features high/low temperature resistance (-4℉-198℉), Waterproof IP69, works perfectly in any extreme weather.
Circular Recording & Parking Lines : With record function, monitor will provide video proof of an accident that happens to be capture by the recording, make your driving safer and more secure. With Parking Lines, you can park or reverse safer and faster, no longer need someone to get off the vehicle to help you see the road or guide you.
Easy to Install: It is wired system, but the package includes all the accessories for system to makes installation easier. Please connect the Red wires to ACC, the Black connect the Metal (Ground), and other 4-pin wires to the cameras as Instruction showed. If you need one more cables or Car Charger, please tell us.
Quality Assurance: Voltage range from 9-36V DC Power to accommodate a wide variety of large vehicles. If you find defective or something wrong or need more cables, please ask us, we are Online 24 hours and offer a 18-month replacement support and lifetime after-sales service.
