Price: $79.99
(as of Aug 27, 2024 21:15:19 UTC – Details)
FEISIKE ADC704 Wired RV Backup Camera with Monitor System
Wired RV backup camera takes the wired connection has a more stable transmission and will not lose signal at any time.
Dual Channels Freely Switchable with 1080P Display
You can manually switch to the channel you want and also set it to automatically switch to the reverse channel when reversing.
Wired Trailer Camera with 150 Degree Wide Angle View
150° wide viewing angle, reliable packing lines and image flip for fast and perfect reversing veteran driver essentials.
1 IP67K Waterproof 2 Cold and Heat-Resistant 3 Night Vision
Safe Driving with Any Signal Delay
The wired backup camera for RV lets you adjust the parking grid lines to portray real-life conditions on the contrary wireless backup camera is always intermittent and delayed unable to grasp the situation behind the scene in real-time.
【Lag-free Wired Connection】FEISIKE RV backup camera takes the wired connection has a more stable transmission and will not lose signal at any time. on the contrary wireless backup camera is always intermittent and delayed unable to grasp the situation behind the scene in real-time
【Dual Channels Freely Switchable】RV camera system provides 2 channels capable of backing, security, and many other uses, you can manually switch to the channel you want and also set it to automatically switch to the reverse channel when reversing. Tip: V2 video input will have priority for safety
【5 Types of Parking Grid Lines】The backup camera for RV lets you adjust the parking grid lines to portray real-life conditions. As an added convenience, you can also toggle the parking guidelines on and off
【Easy 6 mins to Install】RV backup camera and HD monitor. are powered by one power supply, no need to power the camera and monitor separately, just connect the monitor to a cigarette lighter adapter/Acc/fuse etc, then wire the camera and monitor
【Multi-Function RV Backup Camera】Industry-standard IP69 waterproofing ensures complete protection against all kinds of weather, 150° wide viewing angle, reliable packing lines and image flip for fast and perfect reversing veteran driver essentials
