FEEKAA Small Rice Cooker 2 Cup, Mini Japanese Rice Cooker, 6-in-1 Portable Slow Cooker, Travel Rice Maker, Soup Maker, Stew Pot, Keep Warm & Delay Timer, White, 1.2L
Price: $39.99
(as of Aug 26, 2024 20:45:14 UTC – Details)
FEEKAA  1.2L Portable Mini Rice Cooker FEEKAA  1.2L Portable Mini Rice Cooker
4 Cups of Rice and No leftover4 Cups of Rice and No leftover
24 Hours Timer Delay24 Hours Timer Delay
Compact and Space-savingCompact and Space-saving
The 4 cup cooked capacity of this rice cooker makes it ideal for single meals and small families. The rice is delicious and perfectly fluffy. There is never a waste issue because the food is always fresh.
Reservations can be made up to 24 hours in advance. Thus, even during the busiest period of the year, you could choose a cooking function and reserve a time. There will be a prepared meal ready for you when you get back.Depending on your cooking requirements, you can long press up for to 24 hours or add 10 minutes at a time by default.
Families with one person, two adults, or families with children will find the 2-cup capacity to be appropriate.This rice cooker is ideal for taking camping and traveling because it is small and takes up little space.
Convenient CleaningConvenient Cleaning
Non stick Inner PotNon stick Inner Pot
Smart Micom Rice CookerSmart Micom Rice Cooker
Convenient Cleaning
Due to its detachable design, the inner pot and cover may be quickly and easily taken apart and washed in water after each use. Cleaning is a breeze. If necessary, use a heat-resistant glove when cleaning the hot inner pot.
Non stick Inner Pot
A durable nonstick coating on the inner pot makes it simple to clean, toss food with ease, and cook food quickly and healthfully.It features measuring markings for the perfect water to rice ratio.
Enjoy effortless cooking as the smart cooking algorithm is designed to automatically cook delicious rice every time!
Note: The heat element may burn out if it is not totally dry before use or is exposed to moisture while in use.
25-Minute Quick Cooking25-Minute Quick Cooking
It can cook fluffy, tasty sushi rice in just 25 minutes thanks to the smart micom. Even if you’re extremely busy, you may still treat yourself to a satisfying bowl of rice right away.
Multifunctional UseMultifunctional Use
Multifunctional Use
The 6-in-1 programmable rice cooker not only specialized for fluffy and delicious white rice, but also good at brown rice, soup, slow cooking, stewing and steaming, which suits for your daily serving.
Slow CookingSlow Cooking
Slow Cooking
Can be used as a slow cooker which is perfect for soups, porridge, stews, and more! It is best to keep baby food separate from adult meals by using the 1.2L container exclusively for puree. For senior people, it can also be used to prepare nutritious mixed rice.
Variety of FoodVariety of Food
Variety of Food
Whether you are in the mood for a hearty jambalaya, steamed veggies and sushi rice, you can accomplish it all with our mini cooker. The possibilities are as endless as your creativity.
sushi
oatmeal
soup
vegetable
Product Product
Mini rice cooker small 2 cup for all cooking methods
Portable and light, easy to place and carry
Product Name: Mini Rice Cooker
Product Number: FK-RC-00
Rated Voltage: 110V-120V~.
Power Vonsumption: 200W
Rated Frequency: 50/60Hz
Cooking Capacity (max): 1.2 L (2 Cups Uncooked)
Product Weight: approx. 1.4kg
Package List FEEKAA Mini Rice Cooker x1 Inner Pot x1 Rice Spoon x1 Measuring Cup x 1 Power Cord x 1 Note:Always firmly attach the plug to the appliance before plugging the cord into the power outlet.
STEP 1STEP 1
STEP 2STEP 2
STEP 3STEP 3
1. Measure rice with one measuring cup and rinse it if needed.
Please use the small measuring cup included with the rice cooker.
2. Pour water up at the water level line of the inner pot. To suit your personal preference, the amount of liquid can be adjusted slightly (no more than 1/2 of the distance between the lines).
3. Select the desired function by pressing the corresponding button. Once the rice is cooked, the rice cooker will silently and automatically switch to the keep-warm mode.
4.3 out of 5 stars
181
90
4.2 out of 5 stars
123
4.0 out of 5 stars
112
โ€” $39.99$39.99 $109.99$109.99 $119.99$119.99
Capacty
1.2L 1.2L 2L 4L
Wattage
200W 550W 350W 800W
๐Ÿฎ-๐—–๐—จ๐—ฃ๐—ฆ ๐—จ๐—ก๐—–๐—ข๐—ข๐—ž๐—˜๐—— ๐—–๐—”๐—ฃ๐—”๐—–๐—œ๐—ง๐—ฌ๏ผš1.2L small rice cooker 2 cup can cook up to 4 cups of cooked white rice, perfect for 1-3 people. Just the right amount of rice you need and no more leftovers. The compact size (19.5*23*19.6cm) wonโ€™t take up too much space, which is very convenient to store or carry. It’s suitable for small kitchen, office, dormitory, camping, traveling. Plus, its cute and fashionable appearance will match any kitchen decoration.
๐— ๐—จ๐—Ÿ๐—ง๐—œ๐—™๐—จ๐—ก๐—–๐—ง๐—œ๐—ข๐—ก๐—”๐—Ÿ ๐—จ๐—ฆ๐—˜๏ผšThis electric small rice cooker could suit various dietary preferences, including Rice, Brown Rice, Slow Cook, Soup, Stew and Steam. You can choose from a variety of cooking functions with appropriate time by using the smart control panel. The sweetness and nutrition of the rice can be better released during cooking process, and the cooked rice tastes better and more delicious.
๐Ÿฎ๐Ÿฐ-๐—›๐—ข๐—จ๐—ฅ ๐—ง๐—œ๐— ๐—˜๐—ฅ ๐—ฃ๐—ฅ๐—˜๐—ฆ๐—˜๐—ง & ๐—ž๐—˜๐—˜๐—ฃ ๐—ช๐—”๐—ฅ๐—  ๐—™๐—จ๐—ก๐—–๐—ง๐—œ๐—ข๐—ก๏ผšThe reservation function allows you to set the time in 10-minute increments for up to 24 hours. Select the time and confirm the reservation to ensure that your delicious rice is cooked on time. Once the rice is cooked, the small rice cooker will silently and automatically switch to the keep-warm mode without bothering you.
๐—–๐—Ÿ๐—˜๐—”๐—ก ๐—œ๐—ฆ ๐—” ๐—•๐—ฅ๐—˜๐—˜๐—ญ๐—˜๏ผšThe non stick inner pot is easy to rinse and is dishwasher safe with superior durability. The detachable steam vent and inner lid make it simple to clean the rice cooker. And the use of extended steam port can effectively control the overflow of the rice cooker, making it safer to use.
๐— ๐—จ๐—Ÿ๐—ง๐—œ๐—ฃ๐—Ÿ๐—˜ ๐—”๐—–๐—–๐—˜๐—ฆ๐—ฆ๐—ข๐—ฅ๐—œ๐—˜๐—ฆ&๐Ÿญ๐Ÿฎ ๐— ๐—ข๐—ก๐—ง๐—›๐—ฆ๏ผšASSURANCE]The 200w small rice cooker includes user manual, rice spatula, measuring cup, removable pot with nonstick coating.And we offer a 30-day replacement policy and 12-month assurance for FEEKAA rice cooker. Any quality issues we provide refund, replacement or technical assistance.Your satisfaction is our top priority.
