Explore 300 Portable Power Station + 1XSolarSaga 100W: Jackery Portable Solar Generator for Outdoor Adventure Car Camping
Price: $259.00
(as of Jul 28, 2024 16:45:21 UTC – Details)
Jackery Solar Generator 300Jackery Solar Generator 300
Jackery Explorer 300 Jackery Explorer 300 Jackery Solar Generator E300-7-1-PC 1 FAST CHARGE 2 MULTIPLE PORTS 3 MAXIMUM POWER DELIVERY 4 SAFE & RELIABLE
E300 PR背书图 PCE300 PR背书图 PC
Jackery Explorer 300Jackery Explorer 300
SPECIFICATIONS
Capacity 293Wh (20.4Ah, 14.4V) AC Output 110V, 300W (500W peak) USB-A Output 5V 2.4A; 5~6.5V 3A (Quick Charge 3.0) Car Output 12V, 10A, 120 Watt Battery Lithium-ion Battery Weight 13.1 lbs Dimension 9.1×5.2×7.8in (23×13.3×19.9cm) Operating Temperature 14-104°F (-10-40℃) Recharging Temperature 32-104°F (0~40°C)
FAQ
Q1: What devices can the Explorer 300 power?
A: The Explorer 300 can charge/power devices that operate at less than 300 watts and the total wattage of all connected devices should also be under 300 watts as well. If the power requirement exceeds this limit, the Explorer 300 will automatically shut off. Please check your device’s specifications before making a purchase.
Q2: How can I know the working time for my device?
A: You can calculate the working time using the formula: Working time = 300Wh*0.85/operating power of your device. For example, if the power consumption of your device is 60W, the estimated working time would be approximately 4.3 hours. Please note that actual power consumption may vary based on different usage scenarios.
Q3: How long does it take to fully charge the Explorer 300 power station?
The Explorer 300 can be fully charged in approximately 4 hours via AC wall outlet. Alternatively, you have two other recharge options: around 4.5 hours from a car port and around 5.5 hours from a Jackery SolarSaga 100W solar panel (sold separately).
Q4: Can the Explorer 300 be charged while in use?
A: Yes, you can use the Explorer 300 to charge devices while it is being recharged at the same time.
COMPARISON
Capacity
293Wh
256Wh
99Wh
288Wh
518Wh
1264Wh
2042Wh
Output Wattage
300W
300W
128W
300W
500W
2000W
3000W
Support Parallel Connection
No
No
No
No
No
No
Yes
Maximum Expandable Capacity
5kWh
12kWh
Wall Outlet Full Recharge Time
4.5Hr
1Hr
1.8Hr
1.35Hr
7Hr
1.7H
2Hr
Solar Panel Full Recharge Time
5.5H (1*100W)
3Hr (1*100W)
2H (1*100W)
7.5H (1*40W)
9H (1*100W)
4.5H (4*100W)
2H (6*200W)
Net Weight (lbs)
7.1
7.9
2.13
8.27
13.3
32
61.5
GREEN POWER SUPPLY: The power station is compatible with the Jackery SolarSaga 100 solar panel. The integrated MPPT controller enables the solar generator set to operate at its max power point, so that it speeds up the battery recharge, making them ideal portable power kits for tent camping, overland journey and etc.
SPEED UP YOUR RECHARGEABILITY: It takes only 2 hours to recharge 80% battery of the power station through the wall outlet and 60W PD USB-C port simultaneously. You can also recharge your power station with an AC adapator when at home, through the car outlet during a road trip or simply use a Jackery SolarSaga 100.
SAFE & STEADY POWER SUPPLY: Armed with a 293Wh lithium-ion battery pack, the Explorer 300 features 2 Pure Sine Wave AC outlets that deliver stable and safe 300W power. The portable power station weighs only 7.1 pounds. You can simply rest assured in outdoor off-grid activities.
POWER YOUR EXPECTATIONS: Featuring 2* AC outlet, 1* PD 60W USB-C port (input/output supported) , 1* fast charge 3.0 port, 1*USB-A port and 1* DC car port, the power station can recharge itself and charge (up to) 6 devices (e.g.Drones, Macbook, Cameras, etc.) at the same time to satisfy your outdoor needs.
WHAT YOU GET: 1* Jackery Explorer 300 Portable Power Station , 1* SolarSaga 100 Solar Panel, 1*AC adapter, 1* car charger cable, 1* user guide
