EWAY WiFi Magnetic Hitch Wireless Backup Rear/Front View Camera Rechargeable Battery for Easy Hitching of Gooseneck Horse Boat Travel Trailer/Fifth Wheels/RV/Camper Reverse for iPhone iPad Android
Price: $89.99
(as of Sep 03, 2024 03:15:15 UTC – Details)
EWAY Wireless Portable Hitch Camera
A More Easily and Safety Solution to Hitch Your Trailer
Simple use system is ready to use in under one minute. Setup includes just two steps; mounting the camera magnetically to any metal surface and connecting it to a mobile device via WiFi Hot Spot. Portable camera sends images to your iOS/Android device for easier backing up, hitching up, or rock crawling.
Battery-powred Truly Wireless Vehicle Backup Camera for Car/Truck/Trailer Magnetic hitch backup cameraMagnetic hitch backup camera
Wireless design – camera becomes a Wi-Fi hot spot when it is turned on. When the camera is turned on, it creates its own Wi-Fi hot spot that works anywhere, regardless of cellular service and without the need for radio frequencies.
8 Infrared LED Lights – Excellent Performance at Day & Night NIGHT VISIONNIGHT VISION
Get clear real-time video even at very dark night, perfect for when you need a better view for rock crawling, parking, monitoring, or hitching up to your trailer.
With 4 Strong Magnets at Bottom, Install the Way You Like Easy install magnetic base backup cameraEasy install magnetic base backup camera
Magnetic base allows for simple setup and repositioning to suit your needs. 4 rare earth magnets at bottom let you mount the camera on your vehicle’s tailgate or on any other metal spot on the body. Each powerful magnet has 15 lbs of pull, so the camera is mounted securely.
The back up camera with 2 powerful IR LEDs can illuminate the rear view range within 30ft. The back up camera with 2 powerful IR LEDs can illuminate the rear view range within 30ft. wifi wireless backup camera Digital wireless signal backup camera
Portable Camera with Magnetic Base
1 Mount Flexible 2 No Delay on Road 3 Use Phone as Monitor 4 Stable WiFi Signal
Magnetic Hitch trailer backup camera The back up camera with 2 powerful IR LEDs can illuminate the rear view range within 30ft. 150 IR night vision backup camera for car rv truck vehicles 1 150° Wide Viewing Angle 2 Durable Performance 3 IP68 Waterproof 4 Excellent at Night
EWAY Wireless Backup Camera For Cars Trailers RVs Trucks
4.0 out of 5 stars
1,904
4.1 out of 5 stars
195
3.9 out of 5 stars
26
3.6 out of 5 stars
24
20
$89.99$89.99
$109.99$109.99
$189.99$189.99
$45.99$45.99
$84.99$84.99
Installation
Magnetic Base
Magnetic Base/Suction Cup Base
Hardwiring to 12V Power
License Plate Mount
Power Supply
DC 12V
DC 12V
Wireless Range for Vehicle
Under 44Ft
Under 60ft
Under 60ft
Under 33ft
Under 60ft
Under 60ft
Monitor Size
Phone/Tablets Monitor
5″ IPS Monitor
5″ IPS Monitor
5″ IPS Monitor
5″ IPS Monitor
View Angle
150
150
150
150
150
150
Support Camera Channel
1 Camera Channel
1 Camera Channel
2 Camera Channels
1 Camera Channel
1 Camera Channel
1 Camera Channel
Image Quality
720P
1080P
1080P
720P
1080P
1080P
Removable Guideline
Strong Magnetic Mount: – EWAY Magnetic Trailer Camera has built-in 4 large powerful magnets (15 lbs of pull for each) , that hold your backup camera much more tightly than common magnets. This powerful magnetic rv camera can create a powerful attraction that firmly stick your backup camera on any flat metal surface
Rechargeable Portable Camera: – Powered by a built-in battery and connected via Wi-Fi, Powered by a built-in battery and connected via built-in Wi-Fi, the Portable Hitch Backup Camera is effortless to install with no wiring required
Enhanced Infrared Night Vision: – With high-sensitivity CMOS image sensor and 9 automatic Infrared night vision lights, EWAY magnetic wireless camera displays a sharper image in the night up to 30ft. Rated IP68, can fully protected against dust and can withstand being submerged in water up to 1.5 meters (5 feet) for 30 minutes. Safe and patented RV Trailer camera, US Patent number 10,894,515
Stable Wifi Signal: – This WiFi Car Camera works on 2.4GHz Wi-Fi, Recommend to use at vehicles under 35ft, perfect for Truck, Camper, RV, Trailers, Fifth Wheels, Travel Trailers, Fifth Wheels ect Easily attach to SUV, Pickup Truck, Travel Trailer, Horse Trailer, RV Camper, Semi Truck, Tractor or Farm Equipment, for monitoring or vehicle reversing
Real-time Image: – WiFi Magnetic Hitch Camera controls with easy set up to your on iPhone and Android phones or Tablets via ‘RV Camera’ APP, the wireless camera for car is effortlessly installed without the hassle of running wires. NOTE: NOT compatible with Google Pixel phone, Kyocera phone, Motorola phone
