Evron Air Ionizers for Home,Negative Ion Plug In Folding Prongs Mobile Ionizer with Output up to 20 Million Negative Ions/Sec (Blue light 1 Pack)
Price: $14.99
(as of Sep 03, 2024 14:30:16 UTC – Details)
Air ionizers for home,negative ion filtration system,quiet air freshener for bedroom,office,kitchenAir ionizers for home,negative ion filtration system,quiet air freshener for bedroom,office,kitchen
Product Dimensions ‏ : ‎ 3.1 x 1.3 x 1.7 inches; 5.28 ounces
Item model number ‏ : ‎ Q-0050A3
Date First Available ‏ : ‎ July 12, 2021
ASIN ‏ : ‎ B0995CT5YR
Country of Origin ‏ : ‎ China
★★High Output Volume Ionizers for Home & Travel Purpose : EVRON Air Ionizer emits 20 million negative ions per second and can cover up to 400 square feet of space. However, this may depend on other factors such as humidity, temperature, air circulation and the level of contamination in the room. Our Ion Generator work best at 20°C, 45% and 60% humidity.For larger spaces it would be more efficient if you run 2 and keep distance at the same time.
★Soft Indicator Light Ionizer-evron negative Ion use a soft light and conceal under the panel to avoid disrupting you while giving operation indicating.
★Foldable prongs plug in ionizer rare foldable plug negative ion,direct plug-in operation, good travel partner.
★Exquisite charger-similar body size,lightweight for travel purpose, now you can take mini portable size ionizer with you anywhere you go.
★2 Output Channels Design,there are 2 ion output channels on both sides which emit ions at a quicker&more balanced way, works well in Living Room,Hotel Room,Pantry,Bedrooms,Bathroom,Corridor,Staircases and more…
