Price: $329.90
(as of Aug 09, 2024 09:30:23 UTC – Details)
Car DVR/Dash Monitor/Vehicle Video Recorder for RV/SUV/Van/Pickup/Truck/Trailer Rear/Side/Front View
Digital Video Transmission
Adopt Fourth Generation digital video Signal transmission technology, transmission range up to 150ft. It can stay smooth and clear even if speeds up to110 mile.
HD 1080p Video Quality
Full HD Video helps you view the surroundings in real-time. High-quality color and clarity make your driving and reversing safer, reduce the burden of your eyes when need to view for a long time.
Loop Video Record
Support Max 128G memory card(Not Included), can loop record, capture wonderful things on your way, also provide evidence when you need it.
EVERSECU 4pcs Digital HD 1080P Wireless Car Backup Cameras with 9 inch 4ch Quad Display Monitor
IP67 Waterproof
The camera outer casing is closed with a metal gel. Anti-fog and waterproof, suitable for Changeable weather.
Night Vision
Advanced IR technology makes night vision images clearer. Accurately identify lakes, grasslands, stones, etc. protect you from Blind Zone.
Guide Line & Multiple Views
The guideline can be switched on/off freely. Help you predict parking distance. Help you reversing safely. Support single view, dual view, quad view. If you need more cameras. Click our store to buy extra cameras.
if you need add-on cameras, please search ASIN: B08NGBM317 Wireless Car Monitor
Installation Type:9″ Portable monitor, suitable for all vehicles Screen(Display)
Size: HD Full View Digital IPS Screen Video
Resolution: 1920*1080p
Languages: English, Russian, Chinses,France,Germany,Spain,Portugal,Italy,Korea,Finland, Netherlands
Video Recording: Support Max 128G SD Card
Signal Format: PAL / NTSC
Power Supply Voltage: 12V-30V
Screen brightness: 500CD / M2
Wireless Car Camera:
Chips Components: HD HM1246
Signal Format: PAL/NTSC Effective
Pixels: 1280*960p Image
Resolution: 1.3 megapixel pixels
Video Output: AHD Video Signal
Night Vision: The Visible Distance is More Than 10 meter
Lens: 16mm F1.6 6 Glass Lens
Working Temperature: -30 ° C ~ +60 ° C
Installation Guide
Step 1: Choose the “CAM4”, Click “Pairing” by setting Step 2: The Screen show ” Pairing Start 20 ” Step 3: Then connect the camera to the power supply.
Wait for Pairing NOTE:
The camera cannot be used if purchased separately. The camera must be paired with our own monitor before it can be used. Only when we buy a monitor and the camera is damaged or lost, we can buy a new camera to replace or add the camera.
Packing List: 1 x Monitor 1~4 x Car camera 1 X Car Charger 1 x User manual 1 x Power Cable 1 x bracket
STRONG WIRELESS DIGITAL VIDEO SIGNAL TRANSMISSION: 100% No interference, No additional wiring for video transmission.(please note the cameras have to be wired to the power). The wireless rear view camera boosts an digital video signal with an effective 100m signal range which ensures stable & smooth wireless video signals even at a car speed of 85 mile/h.
QUAD Display HD 9 INCHS MONITOR: The monitor supports max 4pcs wireless camera and support 128GB SD Card for recording and playback, The Picture is Clearer Than Most Similar Products. Advanced IPS Technology Created a monitor which Fast Response and without Delay, Making Your Receiving More Confident and Safe.
4PCS HD1080P CAR BACKUP CAMERAS: 18 Infrared Lights and HD 960P CMOS Sensor,Digital High definition Image Processor Will Present Superior Night Vision For You.Super IP69 Waterproof Standard.149° Wide View,Make Your Reversing More Confident and Safety, Please note you have to connect power for the cameras and the monitor.
EASY INSTALLATION: It Won’t Take more than 2 Minutes to Install The Monitor,As soon as You Plugged It to the Car charger,Then It Works.2 wiring methods. It can be automatically turned on when reversing, or always on while driving.
WIDE APPLICATION: Voltage Range From 12-24V DC Power for Most of the Vehicle,Such as RV/Semi-Trailer/Box Truck/5th Wheel/Trailer/Bus
